open the hood and make sure it hasnt broke the shroud that the fan sits in or broke a fin on the fan. if not the bearings in the fan may be worn and the fan needs replacing. hope this helps
the oil light comes on from loss of oil pressure, this can be from two things 1. your oil pump is bad abd 2. your bearings around the crankshaft are bad. If the noise is coming from the bottom of the engine, Then the bearings are bad. If the noise is at the top then this could be the distributor. the distributor drives the oil pump, there is a shaft or a pin/tongue on the bottom of the distributor. See if it is broke. Also look down the hole and see if the pump is broke. It's hard to see but you can with a good light and mirror. Just a note, If your truck has had a knock for a while(like when you start it in the morningand it goes away in a few minutes or seconds) Then the bearings are bad. It's time to rebuild or replace.
yes it is one big nut, however it looks like 4 individual nuts due to the fact that they are a thinly stacked layer or thin nuts held together by what you called the tab washer............only way to replace is to get a new one from ford........
