Question about Whirlpool Washing Machines
I have a AWG345/4 washing machine and when it`s filling up with water it starts to flash E 14, what does this indicate is wrong. Keith
  • 177 Answers
It means it is not getting enough water into the unit quick enough. check the tap is fully opened. if the tap is a quarter turn type tap the restrictor may be jamming in the tap. you can just remove this with a pair of long nose pliers. if the tap is ok check for any kinked hoses. if that is all ok the inlet valve will be faulty inside the unit and not opening up enough and would need to be changed
Posted on Aug 23, 2010
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
LED lights flashing
maybe the washing machine is ok . there is something wrong with led light . the switch can't in a good contact .
home led lights
May 22, 2012 | Zanussi ZWF1420W Front Load Washer
Whirlpool duet washing machine Hot and cold water are inverted when filling up the machine's bassin: I choose cold water and it fills up with hot water. The rinse cycle is fine though.What could be the...
The Cold inlet for this machine is on the right side.. with a blue indicator ring on it. When I say Right this is looking at the machine from the back.. Left if looking at the machine from the front. in other words the inlet closest to the edge of the machine.
If you are able to pull the machine out from the wall a little.. Start the fill cycle with cold water reach behind the machine and feel the supply hoses. If the hose closest to the edge of the machine is warm.. you simply have the hoses hooked up wrong.
Turn off the water.. swap hoses.. and all should be well..
I doubt the blue colour ring was put on the wrong inlet.. but.. stranger things have happened.
The Hot inlet should be indicated with a red colour ring..
In most installs the hoses will cross over each other.. not unusal at all. Always use new hoses when installing a washer.
Good luck
Feb 27, 2011 | Washing Machines
Trying to start the unit but the washing light indicator only flashes.
this means the machine has started the cycle...that is the washing light is flashing. However if nothing happens then the drain pump is not working firstly. Machines usually drain first any bit of left over water then go yo fill up. As you havent ststed the make and model i assume the drain pump is faulty. or the water inlet is not working. More precise info is needed to advise you further
Aug 01, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Jul 25, 2010 | Miele W1903A Front Load Washer
Have a AML 125 front loader which is flashing three lights at us: The lock light flashing very fast plus Rapid and 1200-600 lights flashing. When we power up and close the door it starts doing this and...
Top 10 frontload washer problems
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunnion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completely closing. Tighten door latch, add washers if nessisary to make good contact and close door tighter in case of leaks.Note some models send a signal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Oversudsing: Wrong Detergent, too much detergent, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the thermister/heater is out.
Feb 13, 2010 | Ariston Technologies Washing Machines
What does LF mean?
It is a long fill error. It flashes when the machine control board detected no change in the water level or the water level is not reached in a certain period of time during the fill cycle. Water is probably not entering the tub due to the water inlet valve not functioning or water enters the tub but not properly due to clogged fill hose screens.
Press the Pause/Cancel button to clear the error on the display. Remove the fill hoses from the water inlet valve assembly at the back of the machine and check the screens. Clean the screens and replace it if necessary. Make sure that the water supply valve is open and water is present.
Put the machine in standby mode (only the Clothes Clean indicator is on) and activate the Manual Diagnostic Test Mode to check the operation of the water inlet valve.
  1. Select any one button except Power, Stop, and Stop.
  2. Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds
  3. Press the same button when all indicators on the console are illuminated and "88" is displayed on the Estimated Time Remaining display. A single beep sounds and display shows the two digit console ID number for 3 seconds. The displayed ID number will change to "00" and the Add a Garment indicator will flash.
  4. Select Whitest Whites cycle.
  5. Press Start>Wash/Rinse Temp. The water inlet valve should turn on and fill the tub according to the Wash/Rinse Temp selection.
  6. Press Start to turn off the valve.
  7. Press Stop or Power button to exit diagnostic test mode.
Feb 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
LG washing machine WF-F 6861 CN Problem
ne yabba ardhamayye la rayye bae
Nov 08, 2007 | LG Washing Machines
Washing Machines Logo
108 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
