Question about Toshiba Satellite A135-S2276 Notebook
My battery doesn't work - Toshiba Satellite A135-S2276 Notebook
What battery you use
Posted on Aug 23, 2010
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
It doesn't power on
Your camera can be defected. If you buy new batteries, and it still doesn't work, than you'll probably want to send it back to the manufacturer. First, call them and tell them your problem, and if that doesn't work, than you might want to carefully examine your camera, to check if everything is in the correct place, and their all working correctly.
Jun 11, 2012 | Canon PowerShot A560 Digital Camera
GE 27998GE6-C cordless phone with answering machine handset doesn't work
I can be of help please email me abigail@nkaditelecoms.co.za
An upgrade can be offered, with lower call rates.
Jun 13, 2017 | Lands Phones
Replaced battery & pcv valve now speedomter
Under the battery tray is a common ground point. It'll have several black wires going to a connector that is bolted to the frame. Remove this bolt, clean the area up, and bolt it back in place. If the speedometer doesn't work after this, then you probably need a vehicle speed sensor VSS.
Sep 13, 2011 | 1998 Ford Escort
Where can I buy a battery for the DX-902 Lil Driver golf cart? My golf cart doesn't work, so the first thing I think might be wrong is that the battery doesn't work. The golf cart sat in our...
Dear kimbroberg2
My husband and I did the exact same thing for our grandson when he was 8 months old. We pulled the car out of the attic last night and the battery did not work. My husband called the manufacturer customer service at 714-256-9888. He was told that the batter was too old and would have to purchase a new one. My husband called around for the item description that they suggested and found a comparable battery at Interstate Battery in our hometown. Good luck. I know we were very disappointed when this happened, but there is hope. Hope this helps.
Jun 28, 2011 | Dexton Kid Racer Battery Operated Ride On...
Battery been changed twice and after a week or two the battery will run down again
then your alternator doesn't work, that's why it doesn't charge the battery. If you wan't to know if this is the reason you can try this:
Start your engine, connect a multimeter on the propper battery terminals to test voltage level, with your car still on it must have around 13.5 to 14 volts. Turn on your lights and air conditioning it should not descend more than 13 volts. If it's less than 13 volts then your alternator doesn't work and it has to be changed.
Some people does this other test but is not recommendable: Start your car remove ground terminal if the car remains on, then the alternator is ok (If you have a tester I would recommend the first method)
Jun 27, 2011 | Volkswagen Beetle Cars & Trucks
I replaced the battery and the sirius radio doesn't work - it is stuck on aquiring signal for over 30 minuites. The owners manual says to wait at least 10 minuites and it should resync but it...
Disconnect the negative battery cable for 10 mins, then reconnect it and try. Sometimes it can lock out the Sirius unit, and by disconnecting the negative battery cable for 10 mins, clears out the whole system so it can be booted properly.
Thanks Jay!
Jun 26, 2011 | 2007 Nissan Murano SE
Toshiba Satellite A135-S2276 Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
