Question about Garmin Forerunner 405 Handheld GPS Receiver
It is stuck in compass mode so when i press gps all i get is the compass!!! so I cant put the gps on... hence it is no good to anyone\?
What is calibrate compass on 2004 Buick Rendezvous
Manual Compass Calibration If the compass appears erratic and the calibration symbol does not appear, you must manually put the compass into the calibration mode. To get into this mode, do the following: 1. Turn the ignition on and cycle the DIC to the compass/temperature mode. 2. Press and hold the SET button for longer than three seconds. ZONE # PRESS & HOLD SET TO CHANGE: This display mode will be displayed when you are manually calibrating the system. The current zone number for compass variance will be displayed in place of the # symbol. Use the SET button to select the zone number from the graphic shown to select the current area of the country that you are driving in. PRESS SET TO CALIBRATE COMPASS: After selecting your zone, press the MODE button and this will be displayed on the DIC. Press the SET button and complete three 360 degree turns in an area free from large metal objects. The following two messages will toggle in the display until you calibrate the compass: • DRIVE VEHICLE IN CIRCLE • CALIBRATING COMPASS When calibration is complete, the display will return to its normal mode. 3-61 info obtained from MANUAL OWL
press the helpful button and follow me on fixya for more tips
Compass Variance Zone Procedure DIC Compass Driver Information Center DIC...
http://www.manuals365.com/swf/buick/2004_buick_rendezvous_owners.html?page=200
http://repair.chiltondiy.com/Buick/Rendezvous/Repair-Manual-Online
http://www.repairservicemanuals.com/Buick
Feb 02, 2016 | Buick Cars & Trucks
What is calibrate compass on 2004 Buick Rendezvous Vous
My detector is in compass mode. how do i put it in highway mode?
Press the Menu button and the unit should show "COMBO" if it does then the Radar and compass is turned on. If it only shows "COMPASS" then press the dark or City button to have the "COMBO" displayed. Then wait a few seconds and the unit will exit menu and save your setting.
Dec 15, 2010 | XTR695 Radar Detector
Compass 'pops up' in middle of a training run - want to stop this
You are in the mode that is used to navigate to a location. When the compass is up, hit the "quit" button, then select "stop go to" and it should stop.
Jan 25, 2010 | Garmin Forerunner 405 Handheld GPS...
Compass in 3 parts on the screen
This is normal! The compass looks like this in "course pointer" mode.
When you're looking at the described compass screen, press the lower left button and notice the line "bearing pointer". When you select that line and push the front joystick, you'll notice that the compass needle is "normal" again . And when you push the lower left button again, you'll see that the line has changed into "course pointer". Pushing the joystick again toggles between those two modes. The shifted needle indicates how far you drifted from the course that your route follows. See page 31 of the English manual for details.
Jean-Marc Bouyeure
Jun 20, 2009 | Garmin eTrex Vista HCx Handheld GPS...
Geko 101 wouldn't turn off. Removed/inserted batts, wont turn on
Press the power on button while holding OK until the unit switches on- that puts the 101 into Service mode. Then press the up key until the screen contrast is about right. (or press the down key... to make it darker). You'll be able to see if all the tests pass. Then when you're happy with the setting, turn off.
Mar 31, 2009 | Garmin Geko 101 GPS Receiver
Tomtom 720
New version of software (8.010) takes the compass preferences away. Compass always pointing north is available through the status bar settings. Found this on tomtom support under question, "How do compass settings work?" It has both new and old versions of how to access the compass.
Nov 09, 2008 | Tomtom ONE GPS Receiver
Compass on Rino530 "Sight and Go" problem
I would make sure the compass is turned on. When it is off navigation tools are hard to use.
Nov 08, 2008 | Garmin Rino 530 GPS Receiver
Raymarine C 80 Head up problem
I calibrated my autopilot compass and that resolved the problem. My auto pilot compass was about 100 deg out.
Once i did this the problem was resolved.
Aug 26, 2008 | Raymarine C80 GPS Receiver
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
Oct 10, 2007 | Tissot T-Touch T33759851
Garmin Forerunner 405 Handheld GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
