Question about Samsung NV3 Digital Camera
MEMORY FULL IF I HAVE 15MB OF MEMORY ON MY NV3 CAMERA WHY IS IT THAT I AM RECEIVING A MEMORY FULL MESSAGE. I DON'T HAVE A MEMORY CARD INSTALLED THOUGH AS THE MANUAL SAID THAT I DON'T HAVE TO DO SO YET.
The samsung nv3 does'nt support the sdhc cards. I found out the hard way. Just make sure you use a standard SD card.
Posted on Feb 20, 2013
How many photos or videos do you have on the camera already? It probably won't store more than about 4 shots.
Posted on May 22, 2008
I just got a samsung sensory pleasure nv3 i put a 4 gb memory card in it and it says memory full but the card is empty
Hi
Try formatting the SD card before using it.Also,check the storage destination of the pictures,could be they're storing on your camera and not in the memory card.Make the SD card the default storage device.
Hope it helps.
Feb 20, 2012 | Samsung NV3 Digital Camera
New 4GB SDHC mamory card will not work in my Samsung NV3 camera - I get a memory full message. I have formatted the card and erased internal memory with the card out of the camera and still no joy - any...
Sorry, but your older camera can only use 2GB or less standard SD cards. Fortunately, these are relatively inexpensive these days, and may be found on Amazon, if your local store no longer carries them.
Aug 15, 2011 | Samsung NV3 Digital Camera
I put in new memory card it says memory full
Look through the camera's options to try and find the "memory" section. Then look for the option to format the memory card. This should clear everything off of the card. Be careful, though, if there is anything on the card you want to keep!
Mar 07, 2011 | Samsung NV3 Digital Camera
I have a samsung nv3 camerea , i added a new blank memory card but camera says memory full and cannot take pictures
It may be telling you that the internal memory is full. You must get rid of anything in there. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your new card and do the "format" thing again.
Jan 21, 2011 | Samsung NV3 Digital Camera
Hi, I have a Samsung NV3 camera, I have installed a new 4 GB memory card but it is showing memory full. Is there and internal memory on the camera that is full that requires deleting? many thanks
I've tried to download a manual for this camera to give you the most accurate answer possible, however after a few minutes of frustration I'm going to answer this sort of "off the top of my head so to speak" My first impression is that the 4GB memory card my be beyond your cameras capabilities but first try this. Have you checked the memory card to make sure it's not locked I'll include a diagram check the small circle for the correct orientation the arrow shows the lock position.
Diagram
Once you have made sure the card is unlocked install the memory card and then format the card. Formatting "programs and new card to work with the camera it has been installed into. Also Formatting should be done after each download of pictures to the computer hard drive. In this case formatting cleanse the old pictures off and programs the card once again to give optimum performance between the camera and memory card. If this still doesn't work then I suspect the 4GB card is to large for the camera "firmware and you will need to update your camera on the Samsung web site to a newer version of firmware. Sounds complicated but heck i did it so it's not all that technical. Also the memory card you are replacing may only need to be formatted to begin to work properly again (that's if you were having problems)
Jan 05, 2011 | Samsung NV3 Digital Camera
Sdhc card used in samsung nv3 it says memory full
I don't think that camera (the Samsung NV3) takes SDHC cards. The same is true of many (perhaps most) cameras that were released more than a year or two ago.
You need to use a regular SD card, which -- as you probably know -- isn't any bigger than 2G.
May 20, 2010 | Samsung NV3 Digital Camera
MEMORY FULL MESSAGE WITH NEW MICRO SDHC MEMORY CARD
Your camera may be telling you that the internal memory is full. With the card out of the camera, go into the menu and find "format" to erase the internal memory.
May 04, 2010 | Samsung NV3 Digital Camera
I put a new memory card in the camera and it says
You need to eliminate the pics from the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and do the "format" thing again for the card. Everything should be normal now.
Apr 22, 2010 | Samsung NV3 Digital Camera
Camera says my memory is full
It can only take a 2gb memory card. anything higher than that it won't be able to use. The reason it's saying the memory is full is because it's still using the built in 15mb (something like that)
Dec 05, 2008 | Samsung NV3 Digital Camera
SD Card Wont Work
Check if the SD card is iserted properly into the camera, eventually pull it out and push it back inside the camera. Also remove camera batteries , repeat the operation, and put back batteries.
If the card still does not work test the card into a different device, it is not unfrequent that an SD card comes defective from factory. In this case take the card back to the retailer and a have it changed.
If the card works on a different device, then it may be that the NV3 does not support 4 GB , there is no mention about max SD format supported in camera specs, or in the manual. In this case I suggest testing a 1 or 2 Gb card at the shop, and then buying right one.
Regards
Apr 02, 2008 | Samsung NV3 Digital Camera
Samsung NV3 Digital Camera Logo
212 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
