I've unscrewed the filter at the bottom of my candy c514 and it wont come out , it turns left to right but wont come out.
3 Suggested Answers
SOURCE: Candy washing machine C514 manual
my machine does not start the light works on the panel.
Posted on Oct 02, 2008
SOURCE: C514 STOPS mid cycle
I'm having the same problem. It's new and it did it with the first wash. Can anyone help.
jackie
Posted on Aug 18, 2009
How to do level 76 candy crush
Search for a solution on Youtube. All levels of candy crush take some luck, and lots of tries to finish.
Sep 05, 2013 | Kitchen Appliances - Others
I was just wondering where the filter was so i could clean it out
Most washing machines have a pump filter to protect the pump from obstructions such as coins. The pump filter should be at the front of the washing machine at the bottom left or right. It should be obvious (a square or round flap) but sometimes the filter is hidden behind the front kickstrip panel. A good washing machine filter should have retractable pipe at the side so that you can drain the water into a bowl.
The best way to find out if your washing machine has a pump filter is to read the instruction book. However, you can carefully remove the kickstrip at the front of the washing machine (if fitted) to see if there is a hidden filter. Be careful because they are often flimsy and brittle and can break easily. The kickstrip usually clips into place with about 3 tabs but as I say, they are sometimes easily broken. I usually place a small flat-bladed screwdriver between the top of the kickstrip and the casing and then gently lever downwards whilst pulling forward.
Examples of washing machines that sometimes have a hidden filter are Indesit, Candy and Hoover. Most washing machines do not hide the pump filter. Hotpoint and Creda often have a pump filter hidden in the sump hose (leading to the pump from the tub), which is not meant to be customer accessible. This is a stupid place to put a pump filter because when it gets blocked, most people are forced to call out an engineer.
Taking the pump filter out
The filter should unscrew anti-clockwise. Some unscrew until they come out and some just unscrew a quarter of a turn or so and allow the filter to be pulled out. Make sure you have at least one large towel to catch water and don't take it out at all if the washing machine still has water in the drum (see next paragraph if it has).
Jun 29, 2011 | Washing Machines
Unable to remove filter on machine
Assuming you have located the filter at the bottom front of washer, you unscrew it anti-clockwise to remove and clean.
If there is a small screw in the filter handle, then unscrew it first, before removing filter.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Candy AQUA1000T Front Load
My fabric softener doesn't drain on rinse
You need to locate and clean the pump filter.
It is usually to be be found at the bottom front of washer, behind a drop down cover, or removeable plastic trim at bottom.
Unscrew anti-clockwise to remove and clean.
Hope this helps.
Jan 25, 2010 | Candy Washing Machines
Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Dec 23, 2009 | Candy Washing Machines
Cannot remove pump filter cover -Bosch Exxcel 1400
Before removing the filter have you drained the excess water with the drain hose to the left of the filter? The filter cap should turn around 1/4 to 1/2 turn so the best option is to close it again and then repeatedly try opening it with a little more force each time. The black plastic cage could affect the removal of the filter and once removed if it is damaged you may need to replace it. These are available via most domestic appliance spares stores or directly from Bosch. Once removed check for any black plastic debris in the filter housing and chamber.
Oct 23, 2009 | Washing Machines
jackie
Jul 15, 2009 | Candy CNW136 Front Load Washer/Dryer
My frig is leaking water & bottom tray is full
you need to change the filter on the bottom of the refrigerator, take off the outside cover on bottom of fridge and on the left hand side right above the tray that keeps filling up there is a round filter that unscrews. unscrew it and replace the filter. You can get the filters at Lowes or Home Depot for about 20 bucks, hope this helps.
Jul 12, 2009 | Refrigerators
Filter cap
Remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter & clean out. Refit. If you have manual refer to it. Pl rate me if helped.
remember "left is loose, right is tight. So turn it counterclockwise. It will require some strength or a channel lock tool.
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Jan 19, 2008 | Candy Washing Machines
Washing Machines Logo
Top Washing Machines Experts
