Question about GPS
What force pulls the blood to the lower part of the body?
What is the ideal blood pressure for a male at the age of 75
Any adult person should ideally have a B/P around 120/78. HOWEVER, it can be common for an older person to be as high as 100 plus their age. (ie: 175/x)
In EMS, high B/P begins about 140 Systolic. (Systolic is the upper number. Diastolic is the lower number.)
Most B/P medications work mostly to control the Systolic, but the
lower number is also more important than most realize. When the Diastolic B/P gets over 90, the body may not be getting "perfusion" efficiently. Perfusion is where the body exchanges wastes for
nutrients in the blood by means of the capillaries. In other words,
the body is just not doing a good job of 'feeding itself' and getting rid of the toxins in the blood.
Watch your blood pressure, and see a doctor if it is running high.
You should check with your doctor at least twice each year.
Apr 19, 2017 | The Health & Beauty
Why does my blood pressure go up and down?
When you say that your blood pressure goes up and down, are you talking about major fluctuations or minor ones? Minor fluctuations are really common and occur in almost everyone. Anything under 140/90 is generally considered safe in terms of blood pressure. If you have a 140/90 blood pressure more than once in a seven day period that is not a result of a specific activity or behavior, then you might have high blood pressure. If you are over the age of 60, then your blood pressure will tend to be higher and anything below 150/90 is considered normal for that age range. If your blood pressure ever reaches 180/120 or higher than you need to call 911 or get to your nearest emergency room immediately.
You blood pressure might be higher in general if you are an African American, 55 years of age or older, overweight, have a family history of heart disease, have a family history of high blood pressure, or have a family history of diabetes. Drinking alcohol, smoking, eating foods with a high amount of sodium, using drugs of any kind, taking cough medications, taking decongestant medications such as Sudafed, taking antihistamines such as Benadryl, and taking NSAID's such as Ibuprofen and Aspirin can also raise your blood pressure.
In terms of your blood pressure being lower than normal, this can occur when your body has been at rest for an extended period of time and your circulation has slowed down, when you are dehydrated, when you don't drink enough water, when you first wake up from a nap, when you first wake up in the morning, or after eating foods that have been known to lower blood pressure.
If your blood pressure is only slightly elevated and you don't want to go on blood pressure medications, I recommend trying COQ10, preferably with Bioperine in it. This over the counter supplement takes about 4 weeks to get into your system, but once it has, you will usually start to see a difference in your blood pressure by a minimum of 7-10 points. It lowers mine on average 15-28 points on a regular basis and has kept me off of prescription blood pressure medications (which I have been on in the past).
Mar 23, 2017 | Health & Beauty
Type of food to eat to dissolve blood clots
The 4 powerful food, helps in dissolving blood clot are:
1. Natto: Natto contains an enzyme called nattokinase which may reduce the formation of blood clots, and dissolve those that have already been formed.
2. Apple: This fruit doesn't directly dissolve clots. But, Apple contains a compound called rutin that has been found to be a potential clot-buster.
3. Papaya: It's effective in clot-busting, though, is believed to be due to its ability to eliminate the fibrin in blood clots.
4. Pineapple: Pineapple is the source of bromelain, it possesses anti-clotting and fibrin-dissolving properties.
Jan 31, 2017 | The Health & Beauty
How do blood clots dissolve
1-First Stay active,action of skeletal muscles is very good to prevent blood clots
exercises after long periods of immobility is important.
2-Take a supplement. People who do not get enough dietary intake of Omega-3-fatty acids should consider taking a supplement. They are available in form of fish oils, flax-seed oils and primrose oils
3-Keep the body hydrated. It always helps to take in lots of fluids. A dehydrated body is like an un lubricated body where the blood cells will be forced to stick to each other to form clots
4-Guiltlessly go for dark chocolate
5-Use garlic and turmeric
6-Go for pomegranate and grapefruit
7-Eat more cranberries, grapes, and cherries
hope this will helped you
Jan 31, 2017 | Health & Beauty
What is a normal blood pressure for a person who is 73?
140/90 or lower. Not as low as your readings, though. Please consult your doctor.
Oct 19, 2016 | Health & Beauty
What should my Blood Pressure be I am a woman age 76 yrs.?
I would like to see your rate at 110/70. As one ages the first number seems to get higher and the second number lowers. The 73 point differential sounds high to me especially when you think of the excess pressure you are forcing through your arteries on each pump of the heart. Do you smoke or salt your food?
Feb 26, 2015 | Health & Beauty
What are the health benefits of pectin, the fiber found in apples?
Some of the health benefits of pectin found in Apple are:
1. Reduces the risk of Cancer.
2. Manages Diabetes.
3. Aids weight loss.
4. Boosts bone health.
5. Prevents Asthma.
6. Improves brain health.
Jan 17, 2013 | Cooking
Is walking just as good for your health as running?
Some of the major benefits of walking are:
a. Keeps the heart healthy.
b. It improves fitness in a body.
c. Boosts Immune function.
d. Maintain the healthy weight.
e.It reduces lower back pain.
f. Prevent Diabetes.
g. Increases Good Cholesterol.
h.It limits colon cancer.
i. Improve Muscle strength.
Jan 10, 2013 | Luggage & Travel
What are the main benefits of exercise bikes?
Exercise bikes take pressure off your joints and knees. Also, exercise bikes allow you to work out regardless of the weather outside!
Aug 12, 2012 | Exercise & Fitness
Stop brakes do not light up in back. fuse is ok bulbs are ok and switch by brake pedal is ok spoiler light and back ligth in car do not work.
toyota sucks. buy american. you should probably go to the local native american reserve and collect 6 pints of buffalo blood. Drain your oil and replace it with the blood. The high NO levels in the blood prevent the hydrogen ions from collectively turning into bromide and lower viscosity in the engine. Now, in the alternator, the blood will cleanse the eternal life force of the metal, revitalizing the essence of the car's beauty. This little trick helped me out two summers ago. May the great spirit guide your life force and send you tidings of the warrior.
May 11, 2009 | 1997 Toyota Camry
GPS Logo
386 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
