Question about Maxtor Hard Drive
Maxtor 500 gig internal diamondmax 21
I bought an external enclosure and just want to get my music and movies out of my main harddrive in my pc and use the 500 gig maxtor as an external storage. i tried with no jumper and my computer did not recognize any new device being connected so i bought a jumper and have tried every possible jumper setting using only one jumper ( only eight pegs to place the jumper on) could it be that i need two jumpers? i googled it and a few sites showed examples of maxtor jumper settings but the pictures showed more than 8 pegs for the jumpers so obviously they are talking about a different model than mine. please help me, im going nuts here, thanks
    Scholar:
  • 58 Answers
I have the same Maxtor DiamondMax 21 hard drive (500 GB PATA). I also moved mine into an external enclosure, and needed to set the pin Jumper to Master. Maxtor no longer shows this drive (STM3500630A) on their site nor in the DiamondMax 21 manual, but the manual does show the same 8-pin jumper block in the manual. My DiamondMax 21 also shows a picture of how to set either Master or Cable-Select on the hard drive label.
To set to Master, hold the drive so the power connector is to the right of the 8-pin jumper block and the interface connector is to the left of it. Next, put a jumper vertically (i.e. top-row to bottom-row) across the 1st column of vertical-pins (i.e. the pins that are furthest left).
If you decide to place this drive internally, then jumper it for Cable-Select by placing the jumper vertically across the 2nd column of pins (from the left).
If your drive does not show the 8-pin jumper block on the label, you will find the illustrations on Page 25 of the User Manual (Adobe Reader counts it as Page 31). Here is the link to the PDF manual:
http://www.seagate.com/staticfiles/support/disc/manuals/maxtor/100435213b.pdf
NOTE: After plugging-in my external drive via USB, I first had to erase/format the drive before I could get it to show up on my computer.
Posted on Dec 28, 2009
  • 86 Answers
External USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
Posted on May 07, 2008
Maxtor diamondmax plus 9 hard drive not seen by computer
I'd say you did a good job troubleshooting. Replace the drive.
Dec 29, 2012 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Install internal hdd into external enclosure
yes you can... needs to be the right type i.e. SATA or EIDE that matches your enclosure and (USB) interface board...
Feb 25, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Can I use my maxtor diamondmax +9 as an external harddrive
Yes, this is very possible. All you need to do is purchase a harddrive enclosure. This google link contains shopping results for this item--> http://www.google.com/products?rlz=1C1GGLS_enUS291US303&sourceid=chrome&q=harddrive+enclosures&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
I hope this helps. Let me know if you have any questions.
Thanks, Raph30
Jan 27, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Hard drive connects and then disconnects quickly
Sounds like a bad solder joint or break on the circuit board. If the data on it is important, you may need to use a data retrieval service.
Jan 18, 2009 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
External hard drive enclosure
I too purchased a Nexxtech Hard Disk Enclosure and my Vista-based computer keeps telling me to try a USB 2.0 setup...the USB's ARE 2.0...did you try the setup disk that came with your unit?...I tried on mine but still a no go...I may have to return it to Best Buy & try somrthing different.
May 19, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
My maxtor one touch II enxternal will not paower up!
I took out the harddrive and put it internally into my G5 tower and it worked.
Apr 15, 2008 | Maxtor OneTouch II external hard drive...
Instation of Maxtor diamondmax 21, 160 GB which is connected to my pc running Xp Home. The Bios and xp home do not seem to recognize it. How can I get a installtion software. Please help.
dont think you need a driver unless you are installing it in a raid ...the purpose of sata was to elliminate hdd jumpers and configuration ... just go into the bios and make sure the sata channels are enabled
Mar 21, 2008 | Computers & Internet
Maxtor Hard Drive Logo
760 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
