Pen Drive PD64PLUSMP3 MP3 Player Logo
Posted on May 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pen drive won't mount light stays lite - Pen Drive PD64PLUSMP3 MP3 Player
laikexpert
Level 3:
President:
  • Master 281 Answers
  • Posted on Feb 02, 2010
laikexpert
Master
Level 3:
President:
Answers
281
Questions
0
Helped
272266
Points
1232
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
56
Points
My pen drive canot open or formate.
solve this problem
2000 caravan headlights stay on. And no tail lites but brake lites and turn signals still work and horn beeps randomly on its own.
Replace the turn signal switch. All exterior lights run threw it, except the high mount brake light. The horn also. If the head light switch is on the handle, this should take of it also. If the headlight switch is in the dash, you might have to replace it also if they stay on.
1helpful
My pilot light won't stay lite,replace thermopile and still doesn't stay lite.
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
3helpful
3answers
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
1helpful
Pilot light won't stay lite is thermocouple bad?
Maybe, or maybe the FV system tripped.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
If you have error-code type gas control, then you have thermophile and not thermocouple
Troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
My Philips 51PP9200D/37 tv won't turn on. The lighted power button stays lite but nothing else happens. Could this be the Flyback transformer?
It could but it could be about 50 other things as well. You have a voltmeter, and know how to use it? going to need a service manual as well.
1helpful
Swarovski pen won't write
Did you get an answer to this as my Swarovski pen is doing the same?
1helpful
The heater won't stay lit
CHECK YOUR EXHAUST VENT MAKE SURE THAT IT IS NOT PLUGGED OVER HEATING THE UNIT.ALSO IF IT HAS A FLAME SENSE BAR CLEAN IT AND CLEAN ALL SENSOR OFF.AND MAKE SURE ALL WIRE CONNECTIONS ARE PLUGGED IN TIGHT.
1helpful
2answers
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Top Pen Drive Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Pen Drive Audio Player and Recorder Expert? Answer questions, earn points and help others
