Question about Samsung SyncMaster 753S 17" CRT Monitor
Moniter screen is flickering - Samsung SyncMaster 753S 17" CRT Monitor
    President:
  • 1,561 Answers
The picture board on your monitor is bad, since it flickers, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Posted on Aug 24, 2010
My dell moniter 2010f flickers all the time. I have another moniter on that uses the same card by does'n flickers. I also pugged the dell in by its self and it still flickered. l also down loaded...
Sounds like an issue with the backlight in the monitor. Usually the backlight is built in to the LCD panel so there really isn't a way of fixing this unless you replace the panel.
Please rate my solution to show your appreciation!
Jun 02, 2011 | Dell ST2010 20 inch LCD Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
Moniter is flickering, just bought a new video card, have had the moniter for over 2 years , any solution?
You can disassemble it check it for bad capacitors. Other than that you can check on ebay to see if anyone is selling the boards for that model. Sometimes you get lucky and find someone that has the same model with a broken screen.
Dec 02, 2009 | Samsung 225BW Monitor
White static flickering on Viewsonic VA1912wb
Please check the line voltage 220V AC and check the earthing voltage 3V AC..
Jul 09, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Monitor flickering
Hi
Change the power cable if that does not work the power connector on the monitor may be faulty, Test the moniter on a different computer
Mar 28, 2009 | Acer Aspire 4315 Notebook
G Flatron L1515S 15" LCD
monitor display center line problem
Aug 14, 2008 | LG Flatron L1515S 15" LCD Monitor
My LG Flatron L1515S Lcd moniter is Flickering
i am having also same problem...
Reddy - 9700704407
Screen Shaking
make sure your pins on your mail connecter are 100% ok,then u
UPS of that system place far from the moniter .Insert VGA driver cd into drive and driver update via device manager and restart u r
system.In case ur graphics card damaged the moniter normaly
work as u describe.
Jul 17, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor problem
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. May need to check the caps in the G-2 supply circuit. Also you may have a CRT going flakey. Just a slight G2 level adjustment may suffice also. Good luck
May 19, 2006 | Compaq MV 540 15" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
78 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
