Question about HP vs15 15"LCD Flat Panel Monitor
Where do I plug in the microphone/headset - HP vs15 15"LCD Flat Panel Monitor
    President:
  • 1,851 Answers
The green jack from your headset has to be connected at the rear panel of the monitor, just beside the VGA cable. This is for feeding the audio to your headphones. For more details take a look at this picture:
where do I plug in the microphone/headset - 15d8e9b.jpg
The red (orange) jack from your headset (this one is for the microphone) has to be connected at the back of the pc tower, at the red jack, marked as microphone input. In case you need to extend this jack you may use an extension cable like this. In case you don't need the microphone option (if for example you need just the headphones from the set in order to hear audio, movies e.t.c.) you don't need to connect the microphone jack.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 23, 2010
Why won't my tablet support headsets with microphones while others without a microphone work absolutely perfectly?
If you take a look to the 3.5 connectors, you'll realise connectors are slightly different, that's why.
May 09, 2016 | Tablets & eReaders
Does it have a microphone on it? Because I can't seem to get it to sense my voice. It only works if I plug in the annoying headset piece. Is this necessary?
Greetings - The webcam does NOT have a built in microphone. That's why the headset/microphone is provided with the unit.
You could use a different microphone or headset than the one provided, but again, the additional hardware is required for it to work.
Regards,
Mikeywaf
Jun 09, 2011 | GE 98650 Webcam
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
Cyber Acoustics AC-201 Micrphone Problem
i have cyber acoustics headset and i cant hear anything but my Mic works, my sound is all fine, when i plug my headset out i can hear but when its plugged in, i cant hear anything.
Mar 09, 2010 | Cyber Acoustics AC-201 Consumer Headset
Trust headset HS2900 suitable for apple macbook?
On the MacBook there is no microphone port, if you look closely, it is not a microphone plug, it is a line in plug. Line in cannot record sounds from a microphone without amplification. What I would recommend doing is purchasing this adapter: http://www.newegg.com/Product/Product.aspx?Item=N82E16812186035&cm_re=usb_audio-_-12-186-035-_-Product- With this adapter, you plug your headset and mic into it and then it plugs into the USB port on your MacBook. Then you can just unplug it from the USB port when you are done.
Feb 09, 2010 | Apple MacBook PC Notebook
My Dynex headset with removable microphone does not work. The earphones are fine, but the microphone does not work.
Hello
Usually on default the microphone is not enabled in windows, so you have to do it manually. This is the steps you have to follow.
Control panel
Sound
Recording(or microphone heading, it may differ)
Enable microphone
Now it should work if it was not enabled in the first place.
If this does not work try plugging in the combo in the back panel of your case. or visa versa.
I hope this can help you. Please rate this.
Best regards
Sep 25, 2009 | Dynex Stereo Headset with Removable Boom...
Headset works, microphone does not.
Try to look for the microphone volume in your control panel. Maybe it is just on mute.
Sep 03, 2009 | Cyber Acoustics AC401 Consumer Headset
Broken wire to my microphone on my lifechat lx-3000
You cant wire then directly there is a USB D-A chip that controls the headset converting to 1/8" mini plugs may work one for the mic and one stereo plug for the earcups
Mar 30, 2009 | Microsoft LifeChat™ LX-3000 Headset
My DYNEX microphone wont work
Perhaps you have it connected to the speaker connection? Have you looked at the microphone to ensure there isn't possibly a mute button you have accidentally pressed?
Out of curiosity, how are the others hearing you ask if they can hear you? If you are using the microphone to ask, perhaps they are just yanking your chain?
Jan 24, 2009 | Dynex Earclip Headset with Noise-Canceling...
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
HP vs15 15"LCD Flat Panel Monitor Logo
144 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
