Question about Sewing Machines
The hand wheel appears to be jammed. I cannt hand turn it nor will the motor drive it. However the motor will drive the bobbin winder.
    Genius:
  • 1,788 Answers
There is thread binding your bobbin area, clean your machine with a brush.
Posted on Aug 24, 2010
My bobbin winder on my singer 9015 won't wind the bobbin its trying but won't turn
Remove the top lid.
The bobbin winder on the back has a tire on it that rubs against the hand wheel. Replace the tire if it is worn . Check the spring pressure that causes the tire to stay against the hand wheel. It has to be a good spring. If it is week replace it.
Aug 14, 2015 | Singer Sewing Machines
Toyota Industrial sewing machine bobbin winder not working
possibly seizing up from lack of lubrication or fluff jamming the workings
have it serviced by a service centre ( most any sewing service centre will be able to to the job unless it is still under warranty)
Jul 27, 2015 | Toyota Sewing Machines
My brand new lil sew and sew lss 505 will not turn on
When you say it will not turn is it the hand wheel stuck or the motor will not run it. If it is the motor check the position of the bobbin winder. It may be jammed with thread. Remove the bobbin case/basket and look try to turn it by hand.
Apr 29, 2014 | Sewing Machines
Singer 362 bobbin
It appears from the manual (see pages 9-10, which are on 11-12 of the pdf version) that it is necessary to disengage the hand wheel (loosen the center knob) with the bobbin winding lever all the way to the left, before putting the bobbin on the winder spindle. Put the bobbin on the spindle, then set the winding lever to the right position to engage the spindle drive. Do not tighten the hand wheel knob until after the bobbin is wound and the lever is moved back the left to permit bobbin removal.
If you are following these directions exactly, or you can't get the hand wheel knob loose, you have a mechanical problem to solve. You may need a stronger hand to loosen the knob, or something in the bobbin winder is bent, out of adjustment, or jammed with foreign material. If you are mechanically inclined, you may want to remove the top cover of the machine for inspection.
Dec 02, 2013 | Sewing Machines
Need to put bobin in a merritt 4530
Flip the presser switch up to raise the presser foot. Turn the hand wheel counterclockwise until the needle is in its highest position.
  • 2Hold the hand wheel in place with your left hand while turning the hand wheel knob counterclockwise with your right hand to loosen the hand wheel knob.
  • 3Place the desired spool of thread on the spool pin so that the pin fits all the way through the hole in the center of the spool. Put the spool holder onto the end of the spool pin that is sticking through the spool of thread and press firmly to ensure that the spool holder keeps the spool in place.
  • 4Grasp the end of the thread and hold it taut between the thumb and index fingers of both hands. Snap the taut section of thread into the thread guide post located to the left of the spool pin.
  • 5Pull the end of the thread gently. Wrap the thread around the bobbin winder tension disk near the left front on top of the machine, starting at the side of the tension disk facing you and wrapping around in a clockwise direction.
  • 6Poke the end of the thread through the small hole in the bobbin from the inside out so that the loose end of the thread sticks through the top of the bobbin. Put the bobbin on the spindle, or bobbin winder, and gently slide the bobbin winder to the right.
  • 7Hold the loose end of the thread in place while pressing down on the foot pedal to start the machine. Hold the foot pedal down until the bobbin is as full as desired. The machine will automatically stop once the bobbin has reached capacity.
  • 8Cut the loose end of the thread using scissors. Slide the bobbin winder to the left and remove the bobbin. Hold the hand wheel in your left hand and tighten the hand wheel knob with your right hand by turning it clockwise
  • Apr 05, 2012 | Singer 6510 Sewing Machine
    My Model # 1120 Singer sewing machine needle will not go up and down when motor is pressed. The bobbin winder, however, spins.
    It sounds like your machine is set to wind the bobbin right now, so the drive is disengaged. That would explain why the bobbin winder pin is the only part moving. Check your manual for how to reset the machine when you are finished winding the bobbin.
    Most machines have a way to disengage the drive for the needle while filling the bobbin. Then once the bobbin is filled, you re-engage the drive. Some machines have a separate, smaller hand-wheel that turns and clicks into place. Some machines automatically reengage the drive once the bobbin pin snaps into place away from the drive belt.
    I hope this helps!
    Mar 29, 2011 | Singer 1120 Mechanical Sewing Machine
    I just bought a used juki DDL 8500 industrial sewing machine. It didn't come with manual. I also can't find a bobbin casing. I feel very foolish. There appears to have a bobbin winder on the side....
    I just bought the same machine and mine came with a photocopied manual. There is indeed a bobbin winder on the side, there's a flat section on the side of the bobbin winder closest to you, if you push that forward it connects a wheel attached to a bobbin spoke, to the belt that runs between the machine and the motor. To wind the bobbin, put the bobbin on sideways onto the axis of the wheel that is on the inside of the machine, and push the bobbin winder forward.
    If you're looking for where the bobbin case is located on the machine, if you look underneath the machine on the left hand side, there should be a metal belly, on the left side of the belly is an opening, and in there sits the bobbin casing.
    I think you were asking for either one of these answers, I'm on here troubleshooting for my Juki DDL-8500, good luck with yours, hopefully I can find what I need to know too!
    Feb 07, 2010 | Juki DDL-8300
    Bobbin spindle won't spin
    Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
    Sep 01, 2009 | Necchi 3537 Mechanical Sewing Machine
    Bobbin winder does not work on Model 17651
    Make sure that the hand wheel is engaged by pushing it in. To disengage, pull it out.
    Feb 03, 2009 | Kenmore 15516 Mechanical Sewing Machine
    Kenmore sewing machine older model 1345381
    hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
    97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
    Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
    Sewing Machines Logo
    Top Sewing Machines Experts
    Tally Girl
    Tally Girl
    Chris Wetmore
    Are you a Sewing Machine Expert? Answer questions, earn points and help others
