Hi, i am trying to get my volume working but i cant. The volume is muted, and i can't change that using the icon, it only says open volume control and adjust audio properties but when i click any of them they wont open. When i go onto my control panel and try to open the volume control is says cant find application, the same thing happens wen i try to get on properties on main screen and add remove programs on control panel. Can u please help me get my volume back working, thanks Carl
  • 724 Answers
Device manager and remove audio card drivers reboot and it should find then and reinstall. if not you need the audio driver CD
Posted on Aug 23, 2010
Download driver sd ms pro mmc xd
If you have a hardware mute button on the keyboard, try pressing that. They usually look like a speaker with either an x beside it or a speaker that has a circle with a slash beside it. It may even be colored red.
The following answer assumes you're using XP, Vista, or Win 7.
If there is no mute button, click the speaker icon on the toolbar and see if the 'mute' box is checked. If it isn't, also use your mouse or touchpad to work the slider on the screen to try and turn up the volume.
Lastly, some Toshiba laptops have a separate hardware volume control on the front, like you'd find on portable radios.
Dec 11, 2013 | Computers & Internet
Audio Issues
have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
Jun 16, 2008 | GPS
Volume
Right click the volume icon then click open volume mixer then check if anything is muted then unmute it
May 05, 2013 | Fujitsu Computers & Internet
Hi I have ACER 4738Z Laptop in which i have windows 7 installed, But i have audio problem in that, like in the Volume control it shows as not muted but there is no sound either in speaker or either in...
Try to check the sound level. For an Acer laptop/ Windows 7 operating system, you can set the audio to zero but it does not say it is muted. Just click on the sound icon and the sound level should appear. Adjust the sound level and that should allow you to hear something.
If this does not work, try to go to the control panel (start > control panel > change the view to small icons > choose sound ) You should be able to see there two available sound drivers. Enable the one that says Realtec.
Jul 04, 2011 | Computers & Internet
Cant get the mic to work
Have you set the mic you wish to use with your webcam as Default ?
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Dec 21, 2010 | Gear Head WC330I Webcam
Cant adjust microphone
Make sure your webcam mic is set as default
XP
VISTA
TEST SPEAKERS
Restart computer
Plug the webcam and launch the Logitech dashboard ( toolbar )
Open Settings menu ( 2 gear wheel pic )
Adjust mic to suit
Sep 05, 2010 | Logitech Webcam
The mute wont turn on,on the dell inspiron
Have you tried going into the speaker settings? We'll assume with a new PC you have Vista installed, click the speaker icon on the right side of the tray, and selecting "Mixer" will enable access to volume control for the output devices and for applications.
If no speaker icon is visible To check the volume controls in Windows Vista, click Start and then click Control Panel. Choose Hardware And Sound and then click Adjust System Volume under the Sound section. The Volume Mixer window will open, and you should see volume sliders for Device and Applications. Click and drag the sliders to view the volume level percentages. If the speaker icons show a circle with a red slash, click the icon so the speakers are no longer muted.
Furthermore, you’ll want to double-check all of your master volume and mute settings.
Dec 29, 2008 | Dell Inspiron 4000 Notebook
Hp zv5346us audio problem
Try to look for the sound icon in your task bar. select properties then try to check options then select all settings that are supposedly running in your system uncheck those settings that are set to mute then adjust the volume lever to higher level.ex. Right Click sound icon,-open volume control, When volume controls appear click on the properties,-then select all settings that you might be using then close the volume control panel. then try to run again. if possible it needs restart to take effect the new settings.
Oct 08, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I was given as a gift a acer aspire 3002CLi laptop and i must of muted the sound and i dont know where the volume control is please help.
hi, you want mute the sound ok, it's easy. After you enter the windows see the task bar it contains more icons and application .In the corner of the task bar you can see the clock or time display before that more icons there you see the sound icons it's like the speaker . Double click it the volume control comes select the first options volume bar and select the option mute all.if you could not get the icons from the task bar . then goto
  1. start menu
  2. control panel
  3. sound and volume controls
  4. select the sound control tab
here you can get the voume control tab . after all these process you cant get it please inform
Apr 28, 2008 | Computers & Internet
Sound decoder
Go to control panel --> system --> hardware >> device manager.
If you have problem with driver, there will be a big yellow question mark in your "audio controller". If there is problem, you have to reinstall your audio-driver.
If it is ok, then back to control panel -->sounds and audio devices. In tab "volume", you can see if your system might be "mute" (do uncheck box of mute). And if your volume icon is not in the taskbar, do check the checkbox of "place volume icon in the taskbar".
You can also modify the speaker performance here.
Feb 29, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
