Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
I have miele washing machine honey combe care w2122. The rinse button is now flashing and the maching will not rinse
  • 14 Answers
SOURCE: Miele Premier novo washing machine
Faulty cold inet valve most likely the problem or cold tap off Good luck
Posted on Sep 14, 2007
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
SOURCE: miele novotronic w/m fault light flashing
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
Posted on Jan 05, 2008
SOURCE: aeg 76669 oko lavamat machine not
can you switch back to off - then to orginal programme - only the start light may show - what i did then was press all of the 4 button for rinse, spin short wash and held them in place - fro upto 10 secs - machine seemed to reset itself and it worked
Posted on May 19, 2008
  • 13 Answers
SOURCE: Miele W864 Fault
I have a W844 and the exact same fault occured. I traced it to badly worn brushes on the motor.
Posted on Sep 21, 2008
Technical fault
What is the problem you faces with this machine? Provide more details; please. http://electronicshelponline.blogspot.com/
Nov 29, 2014 | Washing Machines
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
Rinse Light flashes on Miele W829 novotronic
Remove all the load and try to move the drum manually clockwise and anti clockwise. If you notice any friction check the motor separately and the agitator assembly separately.
It could be due to alignment shift causing a wobbly motion or a failure of the bearings.
Check these links:
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlForreplacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html.
Jul 29, 2012 | Whirlpool Washing Machines
Main wash and rinse lights both flashing together and machine stopped
main wash and rinse lights both flashing together and machine stopped
Feb 09, 2011 | Miele Novotronic Premier 500 Front Load...
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
