Question about Maytag MAH2400A Front Load Washer
We have a Maytag MAH2400A Front Loading Washing Machine. First it said "suds" when it came to the rinse cycle, which has happened a few times before, so i switched to the "rinse and spin" option and it started making a funny tinny noise so i stopped it and switched to "drain," which it did, but afterward it flashed the message "dn" and i was unable to unlock the door and liberate my clothes. i put it back on "rinse and spin" after leaving it off for an hour in the hopes that the door would unlock on its own; it hasn't. I unplugged it and that allowed me to open the door, but the clothes had not spun dry. Any idea what might be wrong?? Thanks for your help! - Bridget bridget.wagner@gmail.com
  • Maytag Master
  • 19,396 Answers
Hi Bridget.
The problem happens when too much detergent or the wrond kind of detergent is used (see the manual to find out what kind of detergent is best for your washer).
The machine detects an excess of detergent and prompts SUDS, when you switch cycle to drain it will signal nd to show that there is a drain blockage, probably caused by detergent accumulating in drain pump hose.
Repair is done accessing the hose connected to the drain pump and removing blockage.
On most front locaser the pump hose is accessed through the door located at the base of the machine front side, under the door.
To access the pump disconnect power, remove the plastic trim, open access door rotate anticlockwise drain access and be ready to collect water that will flow abbundantly.
Details are also illustrated on manual.
Always remember to disconnect power before starting.
Posted on Aug 23, 2010
  • Ginko
    Ginko Aug 23, 2010
    Note: On the locked door.
    The door is locked because the machine detects that the tub is full of water. To unlock the door safely, access drain pump and empty water as explained in my previous comment, door should open after removing water and connecting power back.
Sud error code
I found that mine was having a sud error. I removed the lower front panel and removed the filter. It was full of lint and loose change. I reinstalled the filter and haven't had a problem since. On a side note I found something interesting laying inside. A service tech guide wich stated to do exactly what I had done.
Nov 27, 2012 | Maytag EPIC MFW9700S Front Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
    http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
    Hi please go to this above link, it is all explained at length what is going on and what to do.
    This error code indicates that excessive detergent suds occurred during the cycle.
    If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
    There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
    • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
    • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
    Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Error code ''suds'' on maytag front loading washer
    Press Chime and Extra rinse keys for three seconds or until the control beeps. You are now in service mode and your machine should say a new error code. Depending on what that code is, you might be able to reset your machine by unplugging it, and replugging it in. if your codes are now clear, try running machine on spin only or rinse cycle. DO NOT add more soap!!! If this corrects your problem, try running a load with out soap. You may have a lot of extra soap in your machine.
    Mar 20, 2010 | Maytag MAH8700A Front Load Washer
    Sud message Bosch washing machine
    ur using too much soap rinse and spin and use less soapwhen u wash
    Feb 19, 2010 | Bosch Washing Machines
    Our front-loading HE washing machine delivers
    try putting in 2 caps of a citrus or pine bleech straight in to the drum with some old rags. then select a boil wash. the rags will spray the water around the tub, the bleech will clean the tub and make it smell fresh. DON'T put any clothing in whilst doing this. if you are worried about bleech in the machine just select a rinse cycle after. i do this once every 3 months
    Aug 05, 2009 | Maytag MAH2400A Front Load Washer
    Maytag top loading washing machine doesn't rinse completely
    CLEAN OUT THE WASHER DRAIN PROTECTOR IF EQUIPED SINCE NO MODEL NUMBER DIFFICULT TO HELP POST MODEL NUMBER PLEASE
    Apr 07, 2009 | Washing Machines
    Maytag legacy series washer top load-squeaky during wash and rinse
    very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
    Aug 31, 2008 | Maytag MAH2400A Front Load Washer
    Washer wont rinse
    you have a pump problem, need to lean washer back ageist wall go under washer. front left take off both hoses stick finger in pump remove all items from pump &hoses should work now
    Aug 04, 2008 | Maytag MAH2400A Front Load Washer
    GE Front Loading Washing Machine seems to be holding water....
    The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
    Mar 08, 2008 | GE WSXH208A Front Load Washer
    Maytag MAH2400A Front Load Washer Logo
    198 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
