Question about Refrigerators
WHAT IS THE BUTTON NEXT TO THE TEMPERATURE DIAL IN THE MAIN BODY OF BOSCH FD8505 FRIDGE FREEZER?
  • 14 Answers
SOURCE: Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Posted on Jan 17, 2008
docjohn174
  • 943 Answers
SOURCE: fridge/freezer : freezer appears to
hi. thanks for the question .You mean the freezer is frosting up. not the fridge . check the defrost timer. and termination switch. and defrost heater . one of those three parts has failed thanks the appliance doc
Posted on Oct 01, 2008
var-pun
  • 331 Answers
SOURCE: Fridge working intermittently.
i guess there is some problem with the thermostat
get it changed.....
Posted on Oct 08, 2008
  • 19 Answers
SOURCE: Bosch classixx fridge freezer. Freezer
Defrost fridge, remove product from freezer and store temporarily in another freezer, defrost at least o/night, then try again.
Posted on Nov 13, 2008
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
I have a bosch fridge freezer model kgu3220 gb. It is ten years old. For the last few days, the fridge isn't cooling but the freezer works fine. The temperature on control panel is stuck on 11 degrees. I...
Once the fridge is shut OFF for few hours to defrost and then switched ON , if the fridge works with cooling , then the fault is with the AUTO DEFROST TIMER or the circuit -maybe the heater, break in the lines to the timer, heater, the fan.
The build up frost will block the flow of cool air to the fridge from the freezer evaporator.
So remove and check.
Jan 13, 2011 | Bosch Refrigerators
Bosch fridge freezer stops working after approx 8 hours. Starts OK and freezes OK but next day it's warming up. Turn it off and back on again and it starts all over again and the problem reoccurs..
Found a solution at
www.reviewcentre.com/vt100228_start50_orderasc.html
Short out the dark blue and the dark brown wires that lead into the temp control dial. Everything now works. This bipasses a dodgy thermister or something. Of course this might not solve all similar problems but it does seem a common fault.
Dec 10, 2009 | Bosch Freezers
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Jul 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch classixx fridge freezer. Freezer working fine, fridge not reaching a decent cool temperature. slighlty cool only.
Nov 04, 2008 | Bosch Refrigerators
Bosch Fridge freezer will not work
This is a Solution posted by a guy called Sandy Small in october 2005 and believe or not it works
Repair to Bosch fridge freezer KGV3104GB
This MIGHT be the same as yours!
Detach top panel above fridge door and "hinge" it down towards you attached to its connecting wires. See if the connector on the right has a thick black wire (nearest the fridge) and two brown wires. The faulty fridge temp. sensor can be shorted out by connecting the black wire to the brown wire next to it. I managed this by bridging the corresponding points on the PCB with a blob of solder. My fridge freezer works OK now on the freezer sensor. Hope this works with yours!
Sandy
May 25, 2008 | Refrigerators
Hope this helps
Deep diver
Dec 22, 2007 | Refrigerators
Bosch KGU32160 fridge freezer
The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
Oct 31, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
