Question about HP Compaq d530 SFF PC Desktop
What cause error code 511 cpu fan not detected
  • 724 Answers
3 wire conductor fan. The 3RD WIRE IS THE fan sensor located in the fan's electronics this is malfinctioning come in tthe construction of the fan itself.
Posted on Aug 23, 2010
  • HP Master
  • 4,737 Answers
Are you sure that the CPU Fan is running normally? This problem occurs when the CPU fan is stopped working or when it's not running properly, means when the temperature of the cpu is increased and can't be cooled by the Fan. Open the case and check the CPU fan, You can see this by power on the Machine while the case is opened. If possible, try with another CPU fan or clean the heat-sink. Applying Coolant Paste will be helpful.
Also check temperature (cpu temperature) from the Bios Settings.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
  • 480 Answers
Hi, the usual issue of this problem is the fan is already defective and needs to be replaced.
Cheers!!
I have 4 brand new HP Compact 8200 Elite Convertible Mini Towers. 2 are giving me the error message 511 CPU Fan not Detected. On both computers the fans are running, so I am assuming they are not running...
If the option exists to turn off speed control on the fans and allow them to run on maximum I would try that first. Additionally if these are brand new warranted I would exercise the HP on-site warranty if this is available, usually Business machines from HP have on site repair.
Oct 23, 2013 | Computers & Internet
What makes 511-cpu fan not detected and 512-chassis not detected
Are you seeing this error on a system you built or a pre-built system? If it is a pre-built system, check that the fans are running. Next check where the fans are plugged in, the CPU fan must be connected to the CPU fan connector on your motherboard. The chassis (rear case fan) only needs to be connected to the motherboard if you want the monitoring/PWM (modulated fan speed) option. If your CPU fan is powered directly from the power supply, change this.
If this is a system you built or recently updated the case, check your fan power connections, as above. Next check the fan speed. My ASUS board will give the "CPU fan not detected" error if the CPU fan speed is too slow. A different CPU fan will solve the problem. (I got my fan with the CPU; it works fine.)
I hope this helps. Please add a comment with more information about your system for more assistance.
May 12, 2013 | Computers & Internet
are you the one opening your desktop computer?
If you are, check your cpu-fan connector pin if its properly connected to the motherboard
If not
check if your cpu fan are working if it didn't rotate replace it with a new one
Jul 26, 2011 | Compaq (283983-001) Motherboard
check fan if fan ok then check hard ware near fan jack sarfaysamandit fet or transister
if fix your problem click yes for vote
Dec 27, 2010 | Compaq (283983-001) Motherboard
Dell error code 0141
Error code 0141. Msg: Error code 2000-0141. Msg: No drive detected.
This is caused by the intel chipset overheating.
Your drive is usually ok, but the chip controlling the drive is too hot to function properly. Try blowing your CPU fan out with compressed air, then start using a laptop cooler to keep it cool and this problem should go away.
Apr 05, 2010 | Dell Inspiron 1525 Laptop
When i put on my computer, this message apear : 511-cpu fan not detected. I have a Compaq Evo D510 CMT and i use Windows Xp. Thaks for the help
This will likely be caused by a loose connection, if you look inside the machine there should be a cable running from the fan on top of your cpu to the motherboard. If thats disconnected or loose then plug it back in and all should be right with the world!
Dec 24, 2009 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Fan Error on IBM T41
This is normally the CPU fan - is it working?
Is it connected to CPU fan socket on mainboard or a different socket - it must be connected to correct socket or fan will not be detected?
Aug 09, 2008 | Computers & Internet
Error 511
It means the 3 pins for that fan are not working on motherboard . I suggest you use the motherboard 3 pins for the chasis fan and buy a CPU fan with 4 pin setting that connects to your power supply ( much better current )
Jul 11, 2008 | Compaq (283983-001) Motherboard
COMPAQ Evo D310st
Please go to Bios setup and then Load the bios set up default, and restart the system.
If this not work, Please replace the CMOS battery maybe that battery is busted. and the do again"
"Please go to Bios setup and then Load the bios set up default, and restart the system. "
hope this help!
If not solve the problem please notify me, do not rate.
Feb 04, 2008 | Compaq (283983-001) Motherboard
HP Compaq d530 SFF PC Desktop Logo
5,805 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
