CD player runs trys to scan disc but gives a message of no CD disc in player
  • 4,234 Answers
You don't specify the make or model, so all I can provide here is general guidance. If you can gain access to the lens, try cleaning it using a cotton swab and alcohol. That may resolve the problem. If not, then the optics may either need adjustment or replacement.<br /> <br /> Dan
Posted on Aug 24, 2010
  • 75 Answers
Lens is gone.
Posted on Aug 23, 2010
Gigaware compact disc 13-140 will not play CD. It trys to read then displays CD error
Could just need the lens cleaning. You can buy lens cleaning discs since the device is spinning the discs to read them.
Mar 22, 2018 | Audio Players & Recorders
Why does my hhr radio try to load and eject a cd disc when there isn't one inserted
There is an arm in/on the left side of the disc player. Most likely the spring inside it is broken. Leaving the arm in the pushed back position. Some times kids put coins in there also. This will cause things to happen, to include killing the radio and/or cd player.
Aug 14, 2014 | 2009 Chevrolet HHR
My cd-48 sometimes gives disc info but reads no disc when play is pressed???
i found my dads Marantz CD-48 on the attic and had the same problem. Some CD`s the player was able to play instantly others not, getting the Error Message after trying to read the disc. My problem was solved after i opened it up and cleaned the linse of the player with a cotton swab.
Mar 10, 2014 | Marantz CD-48 CD Player
Panasonic CD player gives "no disc" message with disc inside.
There could be several reasons why it would do this. Try very carefully cleaning the lens on the later if its dirty or has finger prints. Beyond that there isn't much you can do.
Dec 27, 2012 | Sony Walkman D-ES51 Personal CD Player
While trying to play a CD in my 2005 Pontiac G6, the CD will not stay in the disk player and comes back out and gives an error message. Is there anything I can do to fix this?
What is the error message? Also- if the disc is scratched badly, the laser in the CD player may not be able to read the disc. Try another clean CD to see if the disc is the problem.
Aug 05, 2011 | 2005 Pontiac G6
An errot c 13 70 appears on my system sony DHC-AZ2D i open the case and i saw that the cd enred but not running (didnot move )then the message appears. note : for one year ago the mechanism of cd was...
The motor may just have seized. With the top off, insert a disc and as it trys to spin give it a little help. If this doesn't work then it needs a new motor or complete mechanism.
Apr 24, 2011 | Sony DAV-DX250 System
My sony DVP-NS725P will not play discs
Run a DVD disc cleaner through it and see if that helps. If not then open it up and manually clean the laser pickup lens. Then give it a go. If that didn't help, then open it back up and replace the optical drive.
Feb 18, 2010 | Sony DVP-NS725P DVD Player
Error message when trying to burn a disc in i Tunes
The problem is with your optical unit, (TSST****), it must be firmware-updated, which version of iTunes do you have?
Dec 09, 2017 | Apple iTunes
Navagation radio with 6 disc player in dash, cd player is frozen on disc 2 track 1. Won't play and gives message of no disc but the player has 6 disc inside of it. Removed radio fuses but remains the same.
Have you tried running a cleaning device through it? The case may be that the laser that actually read the disc is either stuck in place or it has burnt out on it. That's if the cleaning doesn't work.
Feb 23, 2009 | 2004 Cadillac Escalade
Won't read disc
The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 04, 2005 | Aiwa NSX-A115 Shelf System
19 people viewed this question
 Grubhead
Grubhead
