Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
My printer shows error when i insert cartridge
  • 360 Answers
Www.youtube.com samsung scx 4300 toner reset
Posted on Aug 25, 2010
Hp B110a this printer showed an error ink system Failure 0xc19a0023. How do i fix it tel me please please. ????
Try to re insert your ink cartridge ,set the printer into ink replacement mode ,then remove cartridge then re insert it back ,maybe it can help(be sure your ink are not empty )
Aug 02, 2014 | Office Equipment & Supplies
I put the new black and color ink today, but color sign does not show up. It saysYOUR PRINTER HAS PROBLEM. Printer does not working at all. I check the cattridge both of them. Please give me the...
Make sure the cartridges are properly inserted in the carrier. Please follow steps below to determine and fix the issue:
  1. Open the printer cover and remove both cartridges. Close the cover.
  2. Unplug and re-plug the printer into the power source to reset it.
  3. When the printer turns on, re-insert the black cartridge first. Close the cover and check for any errors.
  4. If none, re-insert the color cartridge and close the cover.
  5. Replace whichever cartridge is causing the problem. You can also try to insert a different known working cartridge to determine if the other is faulty.
If no errors, try to print a document.
Jun 24, 2011 | Lexmark X1270 All-In-One InkJet Printer
Toner error for brother printer hl3070cw
To prevent the printer showing "error" or "not recognize" when installing a newcartridge, please try to follow these instructions below:
1) Turn on the printer; take out the cartridge
2) Turn off the printer for a few minutes
3) Turn on the printer, when it says "insert inks", and then insert the cartridge, making sure the cartridge is sitting completely in the slot.
Please shake the toner many times.
Also, if you have a drum kit in your printer, please also check the drum kit and re-install the drum kit.
Jun 16, 2011 | Brother Office Equipment & Supplies
Printer wont print showing C 5 E on display
EC5 error code indicates a short has been detected in one of your cartridges. Try to remove both your cartridges from the printer. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover and check for any error. If none, open the cover and reinsert the other cartridge. Close the cover and check for any error. Replace whichever cartridge is causing the error to appear. You may also try to insert a different known working cartridge to determine if the other is faulty.
May 04, 2011 | Lexmark X2670 All-In-One Printer
Ink system failure....error code 0xc19a0013....what is this error code and how do i clear it....
What is HP Printer Error 0xc19a0013 & How to Solve the Error ? 0xc19a0013 ink system failure error shows in the control panel of printer.
Reason of occurring this error message is listed below:
  • HP printer setup may not be installed properly.
  • Printer cartridges low message.
  • Printer cartridge is damage or not inserted properly.
How to Solve "0xc19a0013" Error Code for HP Printer
  • Change low or empty cartridges: in case ink alert message is display before this message. Changing the cartridges may solve the issue.
  • Make sure the printer cartridge is installed or inserted correctly
  • Remove the printer cartridge and reinstall that.
  • Use HP Printer Automatic Cleaning Utility to Printheads:In case the error message is occurring ,use automatic cleaning utility of printer for printhead cleanup
  • Update the Printer Drivers :It may happens due to outdated printer drivers. We recommend you this to update your HP printer drivers on regular bases for smooth and flawless printing
In case your HP printer still display the error message best option is to dial HP Printer technical support Phone number-1-800-436-0509 (US), +44-800-078-6054 (UK), +61-1800-769-903 (AUS)
1 800 436 0509 HP Printer Technical Support Phone Number
Jan 04, 2011 | HP Officejet 6500 Wireless All-in-One...
I have inserted a new color ink cartridge, but when i close the printer I get an error message that reads 'Cartridge Error, Error #1203'. I have tried two different cartridges with no success. What is...
Yes ok it will be the inks.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jan 05, 2010 | Dell 966 All-In-One InkJet Printer
When i start printer E 7 2 error messge is displaying
Probably It show 2 (two) kinds of signal or error message.E2 or E7.
just problem E2 mean no insert recording paper.
Problem solve: when show this error press color key or black key then try to feed paper this printer.
E7: when show E7 some fine cartridge are not install properly right position.
Problem solve: follow mark where install color and black cartridge.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My printer dont want to print
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
Apr 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
Error #12 Shows on my lexmark x4270 all in one how do i clear it
Hello there,
In my experience I've never come across an error #12 on a X4270. I've seen an error 1200 & error 1203 a couple of times. Did you get this error after installing a new cartridge? then there are chances that the new cartridge that you installed is defective. The best way to figure if out is to take both the cartridge out and power recycle the printer with the cartridge out. Check out if the operator panel says "cartridge missing" when it is powered back on. If it doesn't say "cartridge missing" then the printer hardware is defective. You would need to get it serviced. If the printer comes up with "cartridge missing" message, then either one of the two carts that you have is defective. I would suggest you to insert one cart first and close the cover and check if it says "cartridge missing" If it does come up with that message then insert the other cart too.. If you get Error 1203 on after inserting a cart, then that cart is defective and needs to be replaced.
Merry Christmas!
Dec 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Mar 20, 2008 | Canon I990 InkJet Photo Printer
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
27 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
