Question about Canon Office Equipment & Supplies
Want to know canon xerox machine price model no 2830 & 3300. I dont know what are the price
SOURCE: canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Posted on May 26, 2009
redzventures
  • 149 Answers
SOURCE: I have an IR-3300 Model xerox machine. It was
The two problems may not be related. Adding toner should not under most circumstances cause copies to become light, unless the toner you are using is of a poor quality - I hope it is a Canon cartridge or quality generic. It sounds as though your fixing film or drum unit may need replacing, or perhaps you need to perform a install procedure. As the 'install - toner - start' option is free, try it first:
First press the head key and then the number '2' and '8' keys at the same time then press the head key again. This will take you into service mode - select 'copier' then 'install' then 'toner' then 'start'. This will run throught a cycle that takes a little while, I think about 599 seconds (sorry for been so accurate but unhelpful but that's what I remember from the display - never converted into minutes but you're welcome to).
But if you are having blurry or even dirty or light copies it may be the fixing film. When the copies are printed, immediately check if you can rub off the toner at all by rubbing the print with your fingers - if so this indicates that the fixing unit is not hot enough or there is not enough pressure - check that the fuser is in properly and that the jam release lever is not engaged.
Lastly, it could be your drum unit that is faulty or worn. Totest this you will need to try and stop the machine in the middle of printing before it reaches the fuser - open the front cover and latch down the transport bed with the green handle - remove the paper gently so as not to disturb the ink in any way and observe the image quality - if it is displaying the exact same symptoms then it is not your fuser and is probably the drum unit or dodgy toner - most likely the drum. However, if the image is fine, then it most definetely is your fuser film (and or perhaps the cleaning roller that cleans the film).
Good luck
Posted on Jul 31, 2009
canontech
  • 1219 Answers
SOURCE: not getting dry prints using canon 3300 xerox machine
1) is it canon ir 3300 machine?
2) if it is what does it mean NOT DRY completely?
#) My ques is that you need to eplace fixing film
Posted on Feb 15, 2010
canontech
  • 1219 Answers
SOURCE: Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
Posted on Mar 02, 2010
SOURCE: I have xerox machine of Canon 3300 .the error is
some code is coming that is E0000007 what is that code
Posted on Jul 22, 2010
Xerox IR 3300 Copy Quality Promblem
I believe you might have a Canon Imagerunner 3300, Xerox has a Phaser 3300mfp. Can you confirm the model and what is the quality problem, lines, dots, ghosting, etc.
Jan 14, 2016 | Xerox Office Equipment & Supplies
What is a mining of shine E000805-0000 on xerox machin canon ir 2830
I don't have the service manual for this model but on many canon copy machine E805 is a fixing fan error.
Nov 21, 2014 | Office Equipment & Supplies
Canon ir 3300 machine error code 0064, plz suggest
CLEAN THE DUST & WASTAGE INK ON TRANSFER CARONA IN MACHINE & RESTART IT .
Dec 20, 2010 | Canon imageRUNNER 400S Copier
Not getting dry prints using canon 3300 xerox machine
Jan 30, 2010 | Canon imageRUNNER 2270 Copier
Nov 12, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir 3300 xerox machine display board not working
Feb 13, 2009 | Canon Office Equipment & Supplies
PRINTER
You have to have the telugu fonts installed in the machine otherwise, the other work around, you have to make the Canon print as an image and not as a text.
Apr 20, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
120 people viewed this question
old marine
old marine
