Question about Technics Audio Players & Recorders
I have a technics double cassette player which i've been using recently to dub cassettes to CD. Both decks have recently packed up - the right hand spool doesn't want to turn and the cassette tape loops disastrously. Don't know if it's worth paying to get it repaired as i only use the machine now to dub old cassettes!! Does it sound like an expensive problem?? Thnx
  • 4,234 Answers
There are some rubber parts inside (belt,idler tire) that require changing. This is normal for a unit of this age. Expect a parts cost in the $10-$15 range. Any audio repair shop should be able to perform this repair.<br /> <br /> Dan
Posted on Aug 24, 2010
  • 75 Answers
Go and get it repaired.technics is no1 brand for manufacturing tape decks and problem is with just the belt or wheels.
Posted on Aug 23, 2010
How do you dub cassette to cassette
Hi
If you have a dual cassette deck, then one deck will only play cassettes,whilst the other will have a record facility as well.
Basically you need to place the original cassette in the play only deck and the target cassette in the record/play deck.
Start the playback in the play only deck and immediately press the record and play buttons together on the record deck. Some decks have high speed dubbing but this varies so much that you will need to consult your manual for this.
Cheers
Apr 09, 2015 | Audio Players & Recorders
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
How to record a cassette tape to a cd
Your question is posted under a "CD Shelf System" heading. If you really have one of these, the answer is "you can't". The CD player is a player only, not a recorder.
On the other hand, if what you're asking is how to transfer cassette tapes to CD using a computer, there are a couple of ways. One is to connect a cassette player (boom box, component system cassette deck, etc.) to the line-in jack of your computer's sound card. Download and install Audacity, which is free software for recording and editing sound. Then you can record the sound from your cassettes as you play them into the computer.
Another option, If you want to be fancy and spend a little money, is to buy a USB cassette deck. It automatically converts the cassette audio to digital and sends it to your computer over a USB cable. Recording software is supplied (sometimes the Audacity program mentioned before). Several companies make them. Here's one from a company called ION that some friends of mine have, and it seems to work well for them. They've been converting a lot of tapes of family members, and Audacity has been good for cleaning up tape hiss and enhancing the sound.
Either way, once you have the sound in your computer and processed to your liking, you just need to burn it to a CD using whatever burning software you have. (I use CDBurnerXP. It's free, easy to use, and does everything needed for normal CD and DVD burning.)
Aug 10, 2011 | Crosley 4-in-1 Entertainer CD Shelf System
Need to find user manual. I have a problem in recording a tape. I put in deck1 --- cassette to be recorded in deck2 new cassette start play on deck1 ... turn on record and play in deck2 as...
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Mar 01, 2011 | Technics RS-TR272 Single Cassette Deck
Can i dub from a cassette to a cd on my panasonic sxbs?
No you can not go from the cassette to cd on the unit. You can go from cd to cassette though. The unit is not a cd recorder.
Apr 20, 2010 | Panasonic RXD27 Radio/Cassette/CD Boombox
Unable to to dub from the radio, phono,or cd
As far as I know, you need to press Record button to record from external source. If you press Dub, it will start Dubbing from Tape-A to Tape-B. You might be need to press Record and later press Pause or Play to start recording.
Aug 15, 2008 | Sony TC-WE305 Single Cassette Deck
Dule cassette dubbing
No sir,
you can not dub a tape on single cassette deck, unless you have another cassette deck.
ramesh22
Jun 09, 2008 | Sony TC-WE475 Single Cassette Deck
Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
This is a fairly old and obsolete model and its components are now not manufactured. If you are lucky, some stockists may have replacement part, but normally at very high price.
Nov 06, 2007 | Audio Players & Recorders
346 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
