Question about Sharp R-1480 Microwave Oven
Where sharp service centre in johor bahru
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Feb 22, 2017 | Sharp Microwave Ovens
I have a Sharp Microwave oven of 29 lit capacity purchased in 2003 when it had recently come in Indian Market.From time to time It had developed several problems but as SHARP does not have authorized...
You need to use the wave guide cover, this can be salvaged from any old microwave which you can find from repair shops., It is best to have this in place.
Click on : Waveguide
Jan 24, 2013 | Sharp Microwave Ovens
To repair transformer on board
I don't know what you mean buy "Repair the transformer" replacement is usual.
Contact an appliance maintenance service centre for advice.
Jan 05, 2011 | Sharp R-1850A Convection/Microwave Oven
My Sharp R9H56 microwave oven was overheated and a loud thup sound was heard. May I know what parts was damaged and how to replace them. What are the cost of the replacement?
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 09, 2010 | Microwave Ovens
Sharp R 530BS-sensor cook doesn't work. It appears to work but
In all likelihood the mangnetron has failed, You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Jan 31, 2010 | Sharp R-530BS Microwave Oven
I have a Sharp Carousel microwave model R438DV 1200 watts. There is a small 5x7 screen on the right side wall. It now has a small hole and has char marks on it. When I use the unit a fire starts o
You have to replace that small screen which is called wave guide. If there is a sharp authorised service centre near to your place you can buy the part from them. Do not work the oven without replacing that part.
May 29, 2009 | Microwave Ovens
Microwave problem
You would need to contact service centres via this link
Or you can contact them to ask where to buy spares here:
SHARP INDIA LIMITED [India]
Gat No.686/4, Koregaon Bhima, Tal.Sirur, Dist. Pune 412 216, Maharashtra, India
Tel: 91-2137-252417, 252418, 252419, 252420
Fax: 91-2137-252453
Dec 26, 2008 | Sharp R-1480 Microwave Oven
I'm trying to source a new LCD display for a Carousel microwave model R-380D it doesn't display all characters properly after a power black out. I live in sydney australia and my email is...
You can visit Sharp's Australian support site and click on the "Spareparts Outlets" link under "Frequented Resources".
You might also consider clicking the "Service Centre Locator". If you're lucky, you may find a local servicer who may actually repair your existing display as I do here in the US. This can save you a lot of money.
Sep 18, 2008 | Sharp Microwave Ovens
Sharp R-1480 Microwave Oven Logo
640 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
