Question about Honda 8 HP Engine
What fuel should I use for the Honda GX 110 engine?
  • 21 Answers
Regular fuel
Posted on Aug 29, 2010
How to fix gas from entering oil reservoir
If the float is set too high or the needle is stuck or leaking fuel will overflow into the engine and leak past rings into crankcase.
Nov 08, 2014 | Honda Carburetor Assembly Fits Gx 240...
Gx
carburetor float is either bad or sticking.shut fuel off remove fuel bowl 10 mm bolt once removed pull pin out of float and inspect it at the same time re open fuel valve to allow fuel to push any debris the might be still in the port.re install float and test by slightly pushing the float upward and turn fuel on no fuel should drain unless you release the float if float has any fuel inside replace it if not finish putting it together and problem solved:)
Aug 22, 2014 | Honda 11 HP Engine w/electric start - GX...
Fuel cutoff switch
as always , check all fuses first... no DC power , NO JOY!
post a symptoms and list of tests.
no guessing, post engine size and country.?
lots of engines... which one,(open hood, look up, see sticker see engine name. like F22 or? 2.2L or what?
i cant guess i cant work from someones guess.. ever. (or fail)
sorry.
The EFI system only makes fuel pressure 30PSI
if cranking and spark is good.
the EFI cuts fuel for many reasons. you never stated it.
1: wont start.
2: low fuel pressure.
3: low only running.
the EFI also cuts fuel while cranking at WOT, right foot planted
that is, wide open throttle, super secret, unflood mode.
so if TPS is bad (ground were cut) no fuel, ever.
wow, in the FSM 12 fuel supply drawings, by sub model and engine.
in all case of the 12 drawings, the PCM controls the fuel pump directly
but not the GX, and CVT:GX
GOT A GX?
Nov 29, 2013 | 2004 Honda Civic
I have a Honda GX 160 and I an getting gas in the oil
hi under the carb is a drain bowl .shut the fuel off then take the bowl off 10 mm bolt .then you will see a plastic float hold the float up and turn the fuel on if fuel is cuming out the needle might have dirt on it. turn fuel off now pull the pin out that holds float in place the needle will come down with float spray needle and where needle is seated with carb cleaner now re fit needle and float and hold float up and turn fuel on if no fuel comes out problem sorted. drain oil and fill with new oil.if still leaking fuel you need a new needle
Sep 24, 2013 | Honda Horizontal OHV Engine for Non Pumps ...
No fuel out of fuel pump on a gx 670
what kind of fuel pump, what kind of fuel tank, is there a filter b4 or after the pump, is there even a fuel filter, is the tank empty? all questions you should ask yourself because any one of them can cause this problem.
Sep 14, 2013 | V-Twin Horizontal OHV Engine with Electric...
I have an older model Powermate 8125 watt generator with a Honda GX 390 engine. The unit has been setting up for 4 years so I disassembled the carburetor and soaked it in carb acid. The main jet was c
Clean all the ports and jets with some torch tip cleaners or mechanics wire cut at an angle to be sharp.
Make sur ethe fuel filter is not clogged, or the sreen in the tank.
Also empty the tank and dry it out, then add fresh fuel as gasoline goes bad.
Apr 18, 2013 | Horizontal OHV Engine 390cc, GX Series,...
Honda GX 240 engine has spark, new carb; won't fire. what do I do?
remove the muffler and try it there is a screen inside the muffler that get carbon build up if it runs with out the muffler pry it open and clean it
May 24, 2012 | Garden
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
I have a Honda GX 390 with 13 hp power washer. Overheating.
Make sure the engine is not full of paint or dust debris in it's cooling system. If the fuel mixture setting is very lean, it can cause overheating. Make sure the fuel tank vent is open to prevent fuel starvation. Does the engine seem to be running at full operational speed? If not, it will be short on developed horsepower. Make sure the water source is not partially shut off. Hope some of this helps!
Feb 25, 2010 | Air Tools & Compressors
Honda 8 HP Engine Logo
83 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
