Question about Dishwashers
Dishlex Global 500 Dishwasher has error message "nH" is this the main heating element in the bottom of the dishwasher
SOURCE: Dishlex Global 500 dishwasher
theres a round plug in the top of dish washer pull it out and clean could be cloged or the bottom spram arm can be pulled out and cleaned aswell
Posted on Sep 12, 2008
abhishek33
  • 1239 Answers
SOURCE: cannot change the heating element
hi try the link www.howstuffwork.com
Posted on Sep 13, 2008
Benimur
  • 6966 Answers
SOURCE: i have a dishlex global
Hi and welcome to FixYa,
Offhand, error message "ND" refers to "No Drain" and therefore would require that the drain system be checked, cleaned and inspected for any faulty components. Normally, there would be a drain filter, a sump or sorts, a valve, an impeller and a pump that leads to the drain hose. Access to these components would be through removal of the bottom/kick panel. Further the presence of water at the bottom of the dishwasher indicates that the water is not being flushed/drained out but is leaking from any of the above.
Unfortunately, this is a very messy job.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 15, 2008
SOURCE: dishlex global 500 rinse and wash problem
This was due to a faulty pump motor which I have now replaced.
Posted on Jan 21, 2009
SOURCE: Replace bottom door seal on Dishlex Global 300 Dishwasher - Model DX300SA
HI - i just replaced the bottom seal yesterday. The guy at the spares shop advised me to replace both (bottom of door and bigger seal ) at the same time to ensure no leaks - i did that. The bottom door seal come out when you unscrew the screws - (No need to remove door) and because of all the gunk (from years of washing and age of the rubber) i had to wedge a blunt knife in between (starting at one of the ends) and lever it out - MAKE SURE YOU TAKE NOTE OF THE WAY IT IS BEFORE YOU REMOVE IT! An easy way to remember is there is a nick in the rubber of the old (and new) seal and as it is not centred, just note if the nick is closer to the left or right of the machine, I have replaced mine and there is a little leak and now i wonder if i put the seal in upside down! it has to go in the same way - before you gimmy your's out can you tell me if the nick in the rubber is to the left or right? (LIZ at yodelayeeoo@gmail.com) If I have put in back right there is a chance the screw didn't go through the plastic part of the seal and therefore not holding it in place properly. GOOD LUCK! Don't worry about having to really work at getting the old seal out - you don't need it anymore and i didn't damage mine, regards, Liz
Posted on May 27, 2010
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Dishlex 500 global. How do you take bottom drain
If you remove the entire dishwasher you will have assess to the hose that runs up to the sink drain and to the bottom of the dishwasher. I don't know if it comes apart but if you fully remove it you will get a better look.
Sep 10, 2014 | Dishwashers
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
Dishlex global 500 dishwasher - light inside on but no lights on control panel
Hello misi340 - Try reprogramming the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it was unsuccessful, then the unit could possibly be experiencing a communication error with the control board or wiring failure which only a professional can help with.
Feb 14, 2013 | Electrolux 18 in. ESL4114 Slim-Line...
No drying cycle on the electrolux dishlex 302 any idea's
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Nov 10, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex global 500 rinse and wash problem
Jan 10, 2009 | Dishwashers
Aug 24, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Dishwashers Logo
157 people viewed this question
Top Dishwashers Experts
