My u5 mp3 hanged.After removal from pc screen shows updated. then no functioning of ane keys
    Genius:
  • 1,035 Answers
Try using tcctool version logik dax. Here is the link on how to use tcctool. Please click here.
Posted on Aug 23, 2010
Not able to update firmware.in philips Go Gear player SA3115/97
Hi selvanpradee,
I would suggest attempting a Repair by following the below instructions. This process simultaneously updates firmware as well as returns your product to factory settings. Let me know if this helps by rating/commenting this solution!
You can also access the Product Support site here:
http://ow.ly/6skTv
Your player might hang up. Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software.
NOTE: Contents will be removed by using the repair function.
  1. Install the Philips Device Manager and run it with your player connected to your PC. You can download it under the Software & drivers section.
  2. Click the Repair tab in the Device Manager, press and hold the corresponding recovery key on the player when connecting it to your PC.
  3. Follow the PC screen to recover your player.
You can find the recovery key on your player from the below table.
Sep 12, 2011 | Philips SA3025/37 Flash MP3 Player
I cannot see any sub folder
Dear Sir,
I have samsungYP-U5 2gb mp3 palyer when i connecting to computer its not showing some folders..but when i remove from computer its showing which is not showing in computer .....how can i get that missed folders in computer pleas give advice
Thanking you Govardhan chellem
Aug 08, 2011 | Samsung YP-U5 MP3 Player
My samsung yp-u5 mp3 player was not work properly.it attached the pc they shows not drive in the devise. so i want driver insatallation methode of samsung yp-u5 mp3 playe.
MP3 players use the popular USB connection which sometimes produces errors while connecting. These messages are similar to the "Device Not Recognized" error received with various USB devices. Fixing an MP3 player is sometimes specific to the brand, but they are so similar that most can be fixed the same troubleshooting steps.
Instructions
Device Manager
Click "Start" and go to "Control Panel." Double-click "System" and locate the Hardware tab to find the Device Manager. Vista and Windows 7 users can just type "Device Manager' from the start menu.
Locate "Disk Drives" from the list and double-click "Portable Device." If there is an exclamation mark or other error on the device, go to the "Drivers" tab.
Click "Uninstall" and remove the player. Restart the computer and attach the player reinstall the drivers.
Anti-virus conflicts
Plug the player into a different computer to see if it gets recognized. If it does not, contact the manufacturer to find out if it is broken.
Turn off your anti-virus program on your PC if the device works on other computers. Reinstall the drivers using the device manager as described in section 1.
Plug in the player to confirm the connection.
Other solutions
Check the battery level and make sure the batter is not low or depleted. A low battery will sometimes prevent the player from connecting. Let it charge from the power cord, if necessary.
Verify that you have at least Service Pack 1 installed. Go to the Start menu and type "Run." Press Enter.
Type "Winver" in the box and press "Enter." The Windows version will be displayed along with any installed service packs. Download a service pack from Microsoft, if applicable.
Remove the player from the USB port and push a pin into the reset hole located on the bottom. Reconnect to see if the problem is resolved.
Check the connection to make sure it's secure. The cable should fit firmly into both the player and the computer. Connect to a different USB port if you have one available.
Download updated firmware or use the MP3 Recovery Tool provided under Resources (for Zen players).
Tips & Warnings
A bad cable will sometimes prevent a good connection. Use a different one to isolate the cause.
Jun 15, 2011 | Samsung YP-U5 MP3 Player
I have a Samsung mp3 player yp-u5. it was playing but suddenly it locked and no key works. its monitor is on but nothing works. Thanks for your help.
you probably hit a little slide on the side of the device, it should say hold, slide it to the opposite direction.
Feb 15, 2011 | Samsung YP-U5 MP3 Player
My sumsung U5 mp3 player device showing in computer but the files is not showing and not opening
If the player is showing but not the files it will be good to use a search on the drive- the player as the search object- for all types of files.
If there is some lock on the files then it will not show up and will need to check if the folders are locked, but a search will indicate al files which can be opened.
Also in the first place check the properties of the player which will indicate the memory used in the player.
Feb 12, 2011 | Samsung YP-U5 MP3 Player
Dear Sir, Iam using samsung yp u5 2gb for the last few months. Today by mistake i formatted the mp3 player in my pc. now it is dead Kindly do the needful Regards Rejin.T
If there is a reset button, you try to press it and see any difference. If still no go, try to update the firmware by downloading it from their support website.
Oct 14, 2010 | Samsung YP-U5 MP3 Player
I can't find FM radio in my samsung YP-U5
Press the button with the returning arrow at the top. The use the skip forwards and back buttons until you see the FM radio function. Press the play button to activate and once in you can use the forward and back buttons to scan for stations.
If this doesn't work, you could download emodio and update the firmware.
Feb 21, 2010 | Samsung YP-U5 MP3 Player
Samsung YP-U5 ipod installation problem
dont load crappy software that comes with these things,
windows generic usb storage device drivers works solidly.
just treat it like a flash drive, drag and drop your mp3s into the music folder.
and make sure its charged, i.e. leave it plugged into the computer for al least 30 mins
Sep 20, 2009 | Samsung YP-U3 MP3 Player
21 people viewed this question
 Grubhead
Grubhead
