Question about Nikon Coolpix S3000 Digital Camera
When i turn my camera on the lens comes out and then goes back in on its own, the screen then says lens error?
  • 724 Answers
Dirt in the mechanism
Posted on Aug 23, 2010
ryanriopel28
  • 130 Answers
SOURCE: Camera lens comes out and goes back in when I turn it on.
Sounds like the lens can't get into the proper position. Any possibility of damage to the lens?
Posted on Aug 18, 2007
SOURCE: Lens Error, Restart
Nikon System error help????
Posted on Sep 24, 2008
  • 256 Answers
SOURCE: LENS ERROR
On the camera menu, navigate to the RESET command and select it. THe camera should reset and work properly.
Posted on Jun 13, 2009
guru_dev
  • 315 Answers
SOURCE: I turn my camera on and without coming out all the
It is a pretty major problem for the Coolpix it seems. The internal coupling of the zoom lens is somewhat fragile, and a slight tap at the wrong time can mess up the system. It could have been something as small as a bump while it was being carried in your pocket. The problem is that you'll have to pay for repairs on it since technically it's not a camera error but something that Nikon says happened during usage.
Some owners seem to have been able to solve the problem with a gentle bump to the side of the camera, or some gentle twisting on the lens itself. I don't necessarily recommend that- or, at least I would call Nikon first and see what they have to say about cost of repairs. Other people say that once you do get it fixed, put the camera in Playback mode before you switch it off so that the problem doesn't happen again.
Posted on Jun 29, 2009
iwctoys
  • 126 Answers
SOURCE: the lens comes out then the camera turns off
Your camera has it own doctor built in, if it sees an internal error it will shut down. When a camera turns on it goes through a series of tests, if one of these test fails your camera records an error. If the lens is moving in and out your camera is trying to get the lens to function. As such you have a faulty camera.
Posted on Jul 03, 2009
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
LENS ERROR problem
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 04, 2009 | Nikon Coolpix 3200 Digital Camera
My Canon Power Shot A80 Digital camera goes ON but only shows the screen name Canon then the lens goes back into off - some sounds come on and then E18 shows in the lower left of a black screen. Help.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 09, 2009 | Canon PowerShot A80 Digital Camera
The lens comes out then the camera turns off
Jul 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
TURN ON CAMERA THE LENS GOES IN AND OUT JUST A LITTLE THEN SAYS LENS ERROR
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 21, 2009 | Nikon COOLPIX L18 Digital Camera
Lens
Call 800 730 6597 and we will replace it if it is still in warranty
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Oct 28, 2008 | GE A830 Digital Camera
Aug 10, 2006 | Olympus FE-110 Digital Camera
Nikon Coolpix S3000 Digital Camera Logo
220 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
