Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
My epson stylus sx115 is miss lines when i print in black and white these lines are always the some distance apart
jaylex
  • 417 Answers
SOURCE: EPSON Stylus CX3810 thin white line in every printed line
Hi there the likely thing is that there is a small blockage in the print heads not allowing the jet to fire and causing a blank line. You could remove the print head turn it upside down using a soft cloth clean the print head also use a alcohol based fluid to aid you.
Try this if it's doesn't work then the print head will need replacing you will be able to buy online.
Thanks J
Posted on Jan 12, 2008
Basti
  • 1447 Answers
SOURCE: i have a epson stylus photo r200 do i need all colors to print just black and white?
HI-
Yes you need all the ink cartridges filled or they should have ink in it. That's one feature of epson printer to prevent air to clog nozzles.
Hope this helps
Posted on Oct 18, 2008
gwbm
  • 353 Answers
SOURCE: Black not printing about every 3rd line
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Posted on Feb 01, 2009
cns assoc
  • 677 Answers
SOURCE: How can I remove from my stylus sx115 the ink
Found this on the web. You can download the entire
manual if you like. If you find this helpful, pls rate me.
ftp://download.epson-europe.com/pub/download/3233/epson323393eu.pdf
Posted on Mar 27, 2010
  • 362 Answers
SOURCE: i have no disc to
Hello, you need to go to the Epson web site, download your drivers to your desktop and install them from there. Regards, nicam49
Posted on Feb 04, 2011
Testimonial: "thanku for ur help"
My epson stylus SX115 won't print out.....It says no black ink, but it has color........
Epsons will not print at all if ANY of the cartridges are empty. It doesn't matter whether or not you want to use the color exclusively or not.
Apr 28, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My Epson 1290s is printing with lines running through, less than a centimetre apart. the lines are always in colour, and even occur on black and white printing. the lines always appear to be magenta.
Go to your printer settings and navigate to the "Maintenance" options. Run the options for alignment and nozzle checks. If this does not work, the print heads may need to be cleaned, especially if the printer has not been used for a while. You will have to remove the ink heads and use alcohol to clean them if you feel comfortable doing so. Otherwise, it may be cheaper just to go out and buy a new printer if the print heads are defective.
Feb 28, 2011 | Epson Stylus Photo 1290 InkJet Printer
I get a thick vertical black line/margin down the entire page when i scan on my SX115
Please make sure the scanner flatbed is clean.
You can also try to copy and see if it happens on copying.
If it does, then your printer needs servicing.
Dec 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I am printing a collage of photos on cardstock (for a calendar) using an Epsom Artisan 810. White vertical lines appear evenly spaced along the landscape format. My wife says it is due to the poor...
When you print photos, in Preferences you have to set up the quality of the print to either Best or Photo whichever is the highest one in the list. Hopefully this will increase the quality of the printing, although this is not a photo printer. And you are correct, it's a printer problem.
Nov 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I get a double image with my Epson c120. I replaced the color ink cartridge for about $49 in order to be able to print black and white text but I get this almost unreadable output. Any suggestions?
try doing print head cleaning.. the feature is under the printer properties , utilities tab... then once done.. print a copy of nozzle check..see if there is any missing line..
May 28, 2010 | Epson Stylus C120 Color Printer InkJet
Mar 26, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Paper Feed on EPSON STYLUS SX115
go reclaim to the epson service agent or where you purchase.
Note: take all ink cardriges out. they dont need them.
Feb 09, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Pro 4000 is printing green instead of black
Hi mariann346i am having the same problem with my EPSON RX 595 printer.
i can not print in black and white, it always prints in green.
i also notice something els, even after refilling my six cartridges
and only trying to print in black and white, my yellow ink is running out just as fast as my black so i guess they are somehow mixing together. you should check to make sure your yellow isn`t doing the same.
Jul 14, 2009 | Epson Stylus Pro 4000 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
240 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
