Question about Refrigerators
THE COMPRESSOR IS RUNNING CONTINOUSLY WITH OUT CUTTING, NOT COLD INSIDE
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Possibility of such damages caused by the leakage of freon, so the results are no cold, and devices such as Thermostat for temperature control does not work because there is no cold. there is no automatic breaker which functions to stop the operation of the compressor. or Timer is also damaged. timer function is to stop the compressor periodically.
You can see in wiring diagram of Refrigerator : THE COMPRESSOR IS RUNNING CONTINOUSLY - 614ced4.gif
Posted on Aug 23, 2010
Compressor runs continously even after replacing the thrermistor and cold control. Any ideas?
Freezer not reaching cut off temperature.measure temp with a thermometer. -18 TO -20 should allow thermostat to cut off compressor.
Feb 15, 2016 | Frigidaire Freezers
Samsung RS2530BWP side by side - compressor not running.
sounds like it is tripping on a thermal cut out you need to check ohm values on compressor common pin to left pin value plus common pin to right pin value should equal left pin to right pin value else one of the motors inside compressor is knackered
Dec 19, 2012 | Refrigerators
Refilled 97 jetta ac to capacity it cycles compressor on off remove some runs continous never gets cold
check high pressure with a proper machine and see how many bar you have ,think compressor may be on the way out .
Nov 10, 2017 | 1997 Volkswagen Jetta
I want to program the fan to run continously
I don't see this as a 'programable' feature.
The unit is designed for the fan to run anytime the compressor runs and if you just want the fan to run all the time (without the compressor) just switch it to the 'fan/fan only' position.
May 12, 2010 | Amana PTC093B35AE Air Conditioner
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
So-low freezer try to start, but stops after a second
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 23, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Upright Frigidaire freezer with warning buzzer on constantly
If your'e positive the temp is ok then your freezer cold control may be bad. Slowly turn it toward off. If the compressor doesn't cut off before it gets to off, the control is probably bad. Test it here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
