Question about Epson Stylus DX4450 All-In-One InkJet Printer
Hi I replaced my black ink cartridge in my Epson DX4450 a little while ago with a Tesco equvilant,now it is telling me that black needs replacing,I know its not empty as it has hardly been used.I have tried taking the Chip off but that did'nt work.Now while the printer has not been in use its telling me that one of the other colours needs replacing !! Help!!! Please
  • 724 Answers
I had an epson radio once AM it was a great vacuum tube set.
I had an Epson Dot matrix it also was great.
I figure the name sold when I bought a color epson printer.
It was good until I left it sit.
It cloged up from not being used often enough.
\I bought new ink dispensers since the heads are part of the machine and not set as a cartridge head...
I ripd it all down and tried cleaning and clearing it. I finally bought a new printer and it sits and it is reliable even if I do not use it that often HP...a little over 7 yrs old
Posted on Aug 23, 2010
How do I change ink cartridges for Epson DX4450
1. Make sure the printer is on and open the printer cover
2. Make sure the printer is paused and the output tray at the front of the printer is lowered
3. Hold down the cleaning button for three seconds until the print head moves slightly to the cartridge replacement position, and the power light flashes when the print head is in position. Do not move the print head by hand, it will be damaged
4. Lift up the clamp that holds the cartridge you want to replace as far as it will go.
5. The cartridge will rise partly out of the cartridge holder. For black ink replacement, lift up only the smaller clamp on the left.
6. Lift the cartridge out of the printer and dispose of it properly.
7. Remove the cartridge from its protecting bag. Remove only the yellow tape seal from the cartridge. The yellow tape seal must be removed. Leaving the tape on when you install the cartridge will permanently damage it. Do not remove the tape seal from the bottom of the cartridge.Otherwise ink will leak.
8. Lower the ink cartridge into the cartridge holder with the label on the cartridge face up and the arrow on the cartridge pointing to the rear of the printer.
9. Press the ink cartridge clamp down until it locks in place. Do not press the cartridge itself.
10. Press the cleaning button. The printer moves the print head and begins charging the ink delivery system. This process may take a few minutes to complete. The power light continues to flash while the printer performs the ink charging operation.
11. Never turn off the printer while this light is flashing. Doing so can result in incomplete charging of ink. Even if you do not press the cleaning button, the printer moves the print head and begins the ink charging process about 60 seconds after you replace the ink cartridge.
12. When the ink charging procedure is finished, close the printer cover.
Jun 07, 2011 | Epson Stylus DX4450 All-In-One InkJet...
Do all ink cartridges need to be full to print? I
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Mar 04, 2010 | Epson Stylus DX4450 All-In-One InkJet...
The epson dx4450 does not recognise brand new cartridges, somebody have an idea?
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Feb 20, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Replace ink cartridge
just open the cover .when you open the cover cartridge will come to center just pull all the cartridges one by one don’t make pressure too hard it will come easily if you put more pressure and try to removing it and it is not come out then don’t do it may be you doing wrong . let it be and take help from some one who using printer and know how to fix the cartridges.
Have a nice day and do not forget to rate please...!
Feb 16, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Replaced Epson printer cartridges with Tesco ones - they've worked before but error msg is saying Cannot recognize ink cartridges and I don't know how to override this. Epson RX520 printer with Tesco E272...
Took cartridges back to Tesco Customer Service desk - they didn't quibble even though I didn't have a receipt (Tesco is written all over the packaging and cartridges!) they offered me money back or a replacement. The lady behind the counter advised that her son tells her that there are just bad batches of cartridges and swapping them often sorts the problem. I took another pack and put them in the printer and Hey Presto - printer works just fine and dandy.
Feb 14, 2010 | Epson Office Equipment & Supplies
My Epson DX4450 is playing up. I have used some
I took all the inks out - and holding a cloth over the hole at the bottom shook them and then wiped the contacts with paper towels.
Replaced the contacts and left overnight for ink to charge
This morning working fine - mind you it was Friday 13th
Nov 13, 2009 | Epson Stylus DX4450 All-In-One InkJet...
My Epson cx7450 ran out of ink a while ago. I
Did you remove the cartridges when it went out of ink? If so, the printer head is clogged. Anyway, If you didn't remove the cartridges and the "a while ago" means "Long time ago", is more likely the printer head is clogged. You may need to run the "cleaning printer head" feature from the printer or replace the printer head.
Inkjet printers should be used frequently to avoid this issue.
Sep 06, 2009 | Epson Stylus cx7450 All-In-One InkJet...
Finding how to replace cartridge Epson DX4450
Removal and replacement is pretty straightforward but I know how some instructions and pictures are not clear. So this is what you need to do. Power off the printer and lift the lid up so that you can see the ink cartridges. You can put your fingers on them and move the ink cartridge carrier to the center so that you can reach them easily. If you will look at your new ink cartridge you can see how they have to set in the carriage. There is a small tab that you click up to release and bring the old ink cartridge up enough where you just pick up out of there. By looking at your old one you will see how the new one just falls into place and clicks in. Some printers do not have a small tab that you click up and for those you just grab the ink cartridge from both sides with your fingers and pull up. It will come right out and the new one will click into place as well. Be sure to take off any stickers that protect the ink cartridge before you place them in.
Jan 21, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Ink problems
1. First make sure you have installed the catridge correctly by taking out and placing it again.
2. Then,
The following Epson ink cartridges should be used in your device:
Black: T0431 (high capacity cartridge)
or T0441 (standard capacity cartridge)
And make sure you use the genuine original EPSON catridge.
3. If you are using a genuine one, then TRY TURNING OFF YOUR PRINTER AND SWITCH IT ON AGAIN.
If you do not suceed then,
Please contact Epson to resolve this problem with a technical support representative.
U.S.: (562) 276-4382
6 A.M.-6 P.M., Monday-Friday
(Pacific Time) Canada: (905) 709-3839
(Pacific Time)
Before you call, be near your computer and printer and have ready your product name, serial number and proof of purchase information.
Hope my info solves your problem,
Let me know you want any more ideas......
Oct 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson DX4450 printer
What about it? Huh? Give us a clue will ya? You want to know how to do it? When to do it? Or are you telling us you are doing it?
Put some detail in your posts please. And why post it under a generic problem for all printers. It's fairly obvious your problem relates to an Epson DX4450
Jul 16, 2008 | Office Equipment & Supplies
Epson Stylus DX4450 All-In-One InkJet Printer Logo
166 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
