Question about Dell Latitude D400 Notebook
I recieved a dell d 400 laptop from my brother in usa i m unable to access the setup unable to enable lan card it looks the setup is locked can u help
  • 3,940 Answers
To get the master password to access the BIOS, you will need to contact Dell
http://www.fixya.com/support/r3656360-dell_portable_computer_bios_hard_drive
Posted on Aug 23, 2010
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
12345
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
Unable to connect to the laptop computers
dear Sure there is, but it's supposed to connect via a LAN switch. Since it worked at your old place, did you miss a step? Was the printer plugged into a router and the computer also plugged into the same router?
Start with the wired network setup section in the quick start guide. It might give you an idea on what to do http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_490CW_EN_1578.PDF
Thanks.
May 07, 2010 | Brother MFC 490cw Color Inkjet...
Wireless not working on dell laptop, it is working on other laptops . It works when it is wired
Check for the following; 1. Access code to your wireless lan is correct 2. You laptop physical address is mapped in the router 3. You have enabled DHCP if the wireless lan doesnot require a manual static ip allocation
Mar 14, 2010 | Dell Computers & Internet
Lancard of my laptop affected with electrical failure.
May not be a hardware problem. try two things: first, in Windows, open Network connections and check to make sure that the LAN is enabled; I have seen it accidentally disabled. Second, make sure that it is enabled in the BIOS. to do that, press F2 repeatedly when booting. The BIOS setup screen will appear; you are looking for 'Onboard Devices'; highlight and hit Enter to expand. Arrow down to Integrated NIC and make sure that it is enabled. Once it is enabled, press ESC and 'Save and Exit' to boot again. If neither of these will work, you MAY have to look into an add-on card; however, having the onboard NIC fail is very rare. It is built into the motherboard, so you cannot simply replace it.
Feb 22, 2010 | Dell Inspiron 1525 Laptop
Have wireless internet but no connection to laptop. where's the switch on the laptop to turn it back on?
Hi !
Most of the laptop wireless switch is on the side of the laptop. If there is no physical switch, press the Fn+F2(wireless symbol) to enable the laptop. Double check the wireless LAN if enabled in the system setup. To access system setup, press F2 while the system is booting-up.
Hope this helps !
Thanks.
Jan 23, 2010 | Dell Inspiron 1526 Laptop
Hi brother plz help me about my dell 1520 how to remov bios password
The only ways to bypass the setup password on this mode are:
  1. Contact Dell Technical Support (800-624-9896 USA), verify you are an authorized user of the system and they will assist in generating a Master Password to access the system.
  2. Replace the Motherboard
Dec 07, 2009 | Dell Computers & Internet
My D430 stopped recognizing my LAN card. This
Changing your CMOS battery will reset your BIOS, you just need to configure your bios to enable Local Area Network connections, to do this go to CMOS setup and find network setup utility and enable the LAN, hope this helps...
Oct 21, 2009 | Dell Latitude D420 D430 8x DVD+RW / CDRW...
Dell Inspiron 5100
You can try checking the BIOS first see if its disabled in the BIOS to boot to the BIOS turn on your computer Press bios2.jpg during POST to enter the system setup program.
once in the BIOS you might have a multi page view, or a one page view, look for the INTEGRATED NIC see if its enabled or disabled. just enable it and restart the system then:
download
LAN CARD DRIVER
http://ftp.us.dell.com/network/R54631.EXE
see if it works. hit me back with the result.
Apr 30, 2009 | Dell Inspiron 1501 Notebook
With lan card
please restart your system and at the blue dell logo keep tapping the F2 key, the bios setup screen will open, check in here if the lan card is enabled here or not. if not enable the lan card, once it is enabled from here windows will detect it and prompt you to install drivers.
Further Queries are welcome
If you find my solutions helpfull please do rate me
Feb 21, 2009 | Dell Inspiron 1100 Notebook
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
Jan 14, 2009 | Toshiba Satellite Pro L300 Notebook
Dell Latitude D400 Notebook Logo
98 people viewed this question
Alun Cox
