HI, I HAVE A ZENITH Z8081 LAPTOP.AS I TURN ON THE LAPTOP I GET A LONG CONTINUOUS BEEP & TRIED INSTALLING A FRESH RAM ALSO BUT STILL THE SAME.PLEASE GIVE A BETTER ANSWER. THANK YOU
5 Suggested Answers
  • 135 Answers
SOURCE: No Dispay, No Beep
Try leaving it off but with power to it (should see a small green LED on Mobo) for about 30 minutes or more.
After this time try starting it with RAM installed of course!
If this doesn't work your Motherboard is dead.
Posted on Feb 17, 2009
SOURCE: continuous beep on compaq presario s3200nx
I had the same problem, but then cleaned my computer with pressurized air and it now works. Try that and see if it works.
Posted on Jun 05, 2009
  • 46 Answers
SOURCE: continuous beep at start up
it must be the CPU if nothing else is the problem! do you know how to replace the cpu?
Posted on Jun 29, 2009
SOURCE: my 741gx-m2 motherboard produces continuous
reset your cmos see if this helps pull the jumper on the jp3 circuit on the motherboard and short the 2 and 3 pins with the power off and unplugged then put the jumper back to 1 and 2 ! the bios settings are wrong and this will reset the bios to defaults.
Posted on Jan 27, 2011
When i turn on my lenovo g585 lap it start with one beep and comes the display and go boot with continuous beep sound and stuck the lap
Hi...
Gives continuous beep sound , When my laptop switch on (Lenovo G585). No display but leds (power & battery) were blinking.
Sep 10, 2013 | Lenovo G585 Laptop
When i power up my laptop i get a continuous beep?
It indicates a motherboard issue, sub out the ram memory one at a time to see if that will fix it, and remove the main battery, if no change! the motherboard will need to be evaluated.
Jun 23, 2012 | Gateway MX8711 Notebook
Wireless driver for z8081
Please visit the link provided below :
http://www.driverstools.com/zenith-drivers/driver-zenith-director-z8081-notebook-for-windows-xp-vista-7/
Feb 13, 2012 | Computers & Internet
Hi mine wont show screen at all! i reset ram no help. i turn it on no screen n after about 20 secs it has one long beep?? i cant tell if its loading or not!
the long beep indicates faulty ram oir graphics card, i would say ram, you also need to reset the bios, via the cmos jumper or battery, continuous long beep is a dram error, so the ram is faulty, get some new ram and make sure its specs match the computer
Feb 14, 2011 | Gigabyte GA-945P-S3 Motherboard
One long continuous beep on startup
That's a RAM error. First, open it up, remove power cord and remove the RAM sticks then put the power cord back and turn it on. Will be the same beep. Then power off, put one RAM stick in, and power on again. If no beep, put the other stick(s) in (it may be just a bad contact). If same continuous beep, remove stick and put the other one in, by the same procedure. Power on again and see if the continuous beep is coming again (if it's not, then first RAM stick is faulty). This way you can see which RAM stick is faulty further on depending on how many RAM sticks you have. If it does it on all of them, it may be the slot(s) that is faulty you can only figure it out with a new RAM stick.
Jan 26, 2011 | Sony VAIO VGC-RC110G (VGCR110G) PC Desktop
I didnt use my laptop Acer Aspire 5517 for like 2weeks, when i had to turn it on it started with a continuous beep while loading BIOs. then stops at final start up.
Hello, From the problem you have stated, once there is a continous beep on a system or laptop, majorly it is a RAM problem, RAM means random access memory.Since you said it is making that noise, you can remove the RAM, clean it pins and re-insert it properly into its slot,if the problem persist then you need to get a new RAM,not just anyone,the one that is supported by your laptop. Regards
Dec 09, 2010 | Acer Aspire 7520-5185 Laptop
Continious beeping
sounds to me if the beeping is like that its the ram but it could be a bad board try the ram first
Jul 12, 2010 | ASUS P5PE-VM Motherboard
Toshiba laptop running w7, when i turn laptop on it goes straight to start in safe mode or normal, tried safe mode but get a continuous beep, then it switches off, then turns itself back on again, with the...
Thats because your lap top needs to be reebooted in a format to reconfigur itself unfortunatly its not doing that please! do an early system restore to when it was working and save those settings for the next time this happens ok! and save all your current files just in case you need to wipe your whole drive to origibal settings ok!
Mar 26, 2010 | Computers & Internet
My Acer Aspire One netbook worked for a yr and now it locks up soon after turning it on & loading windows and eventually starts a continuous beep. I have reloaded the software back to default settings...
hi, if it was the processor you won't get any beep sound and i don't think the laptop would even load windows as you said it is a ram problem open the laptop and try to change the ram of dimm or get a new ram .
Jan 17, 2010 | Acer Aspire One PC Notebook
Will not boot up & I get a continues beep noise
once turn off ur pc abd remove ram and fix it in other place of ram
Sep 25, 2009 | Computers & Internet
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
