Question about Acer Aspire 3680 Laptop
Needs to be set at factory settings but I can't find how to do this or wether it can be done. Can you please help?
  • 45 Answers
Read the User Manual or if you don't have it, download it at Acer web sites. Search for "Restore the Acer Aspire 3680" in the manual or the web.
Posted on Aug 23, 2010
I have done a factory reset on my Asus eee but now can't get the @ sign up? Any solutions please? Thanks Tony
When you were setting up after factory reset did you select the keyboard country? This needs to be set to the correct country!
Jun 06, 2015 | ASUS Computers & Internet
Samsung sf-365tp wont answer incoming calls
please reset the phone set to factory settings
Sep 09, 2008 | Samsung Lands Phones
Screen turned yellow
Hello
Just do a factory reset to your set and see whether it helps you. If it doesn't help you to correct its color, T'Con board [Timing Control bard] of your set needs replacement. But before replacing this card, a thorough check should be done by any experienced service technician. If the board needs repalcement, it will be best it to be done at the Authorised Service center for Sharp at your town.
Anyway, just reset the set to its factory settings first. To make it to its factory set values for all parameters, Get into it Menu, surf though, select "Reset" and press Enter. OK.
Nov 02, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I have a LG KH5200 and I want to do a factory reset on it, how do I do that?
To reset your mobile to 'factory default'
- Go to 'setting'
- scroll down until you see 'Restore factory settings' ,click on it,
- It will ask you ' are you sure etc etc ....... '
- Click 'yes'
Done : )
Please rate if my solution was helpful for you, thank you.
Jun 21, 2011 | Cell Phones
I need to reset my Nokia 5130 to factory default. I have tried to get the Mastercode via a imei calculator but with no luck.please help?
To restore your phone settings to factory settings go to
Menu > Settings > Rest. factory sett.
You will see two options
  1. Restore settings only — to reset all preference settings without deleting any personal data
  2. Restore all — to reset all preference settings and delete all personal data, such as contacts, messages,
Select one of these based on your requirements and yeppeee! you are done. :)
Jul 12, 2010 | Nokia 5310 Cellular Phone
Dish tv won't come on say's digital channel 3
Hi friend,,,
welcome to fixya
Wether the signal menu is there,,if it is then check the signal percentage. it should be above 45% atleast...if its not the problem then do a factory settings of reciever and again refresh it,,,
sure it will work
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | iLO 3200 32 in. LCD Television
Restore to factory settings
UNLESS YOU HAVE MADE A BACKUP OF YOR 'REGISTRY FILES' YOU MAY NEED TO RE-INSTALL THE OPERATING SYSTEM AGAIN THEREBY OVER-RIDING THE CURRANT SETTINGS.
BUT! PLEASE MAKE SURE YOU HAVE DONE A FULL BACK-UP OF YOUR PERSONAL DATA FIRST BEFORE YOU BEGIN, UNLESS YOUR O/S IS ON A SEPERATE PARTITION??
Apr 10, 2009 | Acer TravelMate 4320 Notebook
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Feb 01, 2009 | Hitachi 57F500 57" Rear Projection...
Sony kv32ds60u engineers menu
If you did not save the damage that you did, or do any damage from over-adjustment, you can make a re-set to before the adjustments were made by simply unplugging the set from the AC mains for about 10 to 20 seconds. If the improper parameters were saved, or damage was done from over adjustment, then this procedure will not work for you.
Read on for more details:
There is no default actual default. Each set is individualy set up for its optimum performance. At the factory, during the manufacturing process they set the EPROM firmware parameters to a so-called reference value before they start the calibration. This is done during production on the burner that programs the EPROM.
If the paramters are too far off to have the set working, you will have to take the set for service at a factory service rep. The factory service shop will most likely have to change the complete circuit board that constains the uPC EPROM with a new one that has the reference factory set-up. They will then have to go through the complete set-up with calibration procedures using the factory recomended calibration standards instrumentation to match for best performance. To manualy do a full calibration on the test bench it can be about 2 hours of work.
Because the factory service setup was not meant for consumer use, it is possible to over adjust parameters to the point where you can lock the set out of operation, or actualy do damage by over-adjustment.
Jerry G.
Apr 18, 2008 | Televison & Video
741GX-M Sound not working, sound cards not being recognised
plz check wether u have installed xp service pack 2. if u have done this then go to the cmos settings and check wether the onboard audio is enabled or not. then install the correct driver for that device
Oct 21, 2007 | EliteGroup 741GX-M Motherboard
Acer Aspire 3680 Laptop Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
