Question about Garden
I have a victa 2 stoke comando lawn mower code 7, type 03463046 from sotheren cross industries bloemfontien RSA. My problem is the carburator. I have used unleaded petrol and while standing during the winter the carburator seals and diaphrame was completly damaged. where in south-africa coa i get a kit to repair it or buy a new carburator. regards Danie.
  • 211 Answers
SOURCE: My lawn mower doesn't start
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Posted on Dec 22, 2008
  • 2418 Answers
SOURCE: clean old petrol can thoroughly
Not to worry, just drain out any old gas, put in a little new gas, shake it a little, pour that out fill it up and use it. If its bad varnished w/ old gas use stuff called Seafoam pour it in, shake it up let it sit over night and pour that out use like normal.
Posted on Aug 01, 2009
RonInFla
  • 86 Answers
SOURCE: Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Posted on Apr 18, 2010
vincob
  • 718 Answers
SOURCE: what type of fuel do I use in my push Poulan Pro
If your mower is 2 cycle than there is a mixture, if it is 4cycle than there is no mix. Call your local repair shop and give them model number and they can assist you or call the place where you purchased the unit.. Good Luck....
Posted on Mar 12, 2011
Knucklebstr
  • 222 Answers
SOURCE: I just purchased a poulan lawn mower at Kents.
You do not mix gas in a 4 cycle engine. You have to mix gas and oil for a 2 cycle engine, such as in a weed whacker, chainsaw, or leaf blower. I do not know of any 2 cycle Poulan mowers (or any other brands for that matter). Unleaded gas is all you can buy in the United States and all current mowers will run on it, although they really don't like that new ethanol additive. If your mower is new then it should have come with an owner's manual which will explain what to do, as well. Hope this answers your question.
James
Posted on May 27, 2011
What is the victa lawn mower 35 classic a two stroke or a four stroke please.
search on a victa 35 classic makes it 4 stroke
its a brigs and stratton 3.5 engine on aluminum frame + plastic rear catcher
Sep 03, 2016 | Garden
Victa lawnmower manual 460 Pro
You want a manual for a victa or are you looking for an answer regarding a victa? If you want a manual then a good lawnmower dealer can probably help, if not you can try www.buyamower.co.UK or f.g.adamsons
Oct 14, 2014 | Garden
How to change cord victa corvette 160cc 2stroke electronic ignition
On assuming its fitted with a victa 2 stroke engine in which case unscrew the 3 cross head screws on the top plastic cover and remove it. You should then see the top of the engine and the recoil starter. Undo and remove the 3 bolts holding the starter to the engine. Remove the starter housing gently as there will be a large o ring under the stater. Once the starter is off you can undo the centre bolt and remove the recoil pulley and spring. When refitting starter smear a little oil on the large o ring to stop it from being damaged
Oct 11, 2014 | Garden
I have a Victa tornado 2 stroke lawn mower a VSX160 that would not start. i have replaced the spark plug and it is still not starting. I have been told to check the air filter but for the life of me i can...
Hi Mary, the air filter is on the carburator.There is a cover over it that just snaps off or is held on by a couple of screws. The carburator is where you can adjust for low or high speed with a lever or have a cable going to it to adjust the speed. It might also have a primer on it. That is the carburator. Remove the air filter take a look at it for dirt, grass clippings, etc. especially in the bends, clean it as best you can with air or tapping it on the ground. After doing that see how much is left on it. Air has to go through it so decide if you should replace it, they are not very expensive so I would buy a new one. Hope that helps you out. Best regards and good luck.
Jan 09, 2011 | Garden
Need manual for Victa - 3012TX -11.5HP I/C Industrial - 5 Speed Transaxle - Ride on mower
Check this link out for exploded views ... maybe will help
http://www.krysiak.pl/download_files/MURRAY/31721X88B.PDF
Oct 17, 2010 | Garden
Victa 2 stroke starts OK then stops
After much mucking about, discovered that the washer on the fuel cap is missing. When the fuel cap is tightened it seals the fuel tank. Eventually the motor is starved.
It then starts and runs for progressively shorter periods.
Oct 07, 2009 | Garden
Check and service diff lube on ride on a victa lawn mower
You have to disassemble the diff if you want to clean out the old grease, But another way is to put a grease nipple on it. There are two types of grease used in these they are: Bentonite grease & graphite grease.
Jul 25, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Dec 22, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Victa lawnmower
how do you replace the zip cord on a victa tornado last years model
Oct 12, 2008 | Garden
Garden Logo
148 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
