Question about Home
Whenever the toilet flush is used by pressing the knob,a huge noise comes when flush regains it place.i have got pressure pump in my flat where the pressure is well maintained.can i get rid of this big noise please ?
    Genius:
  • 1,011 Answers
It is the valve in your ball **** check ball **** or replace
Posted on Aug 23, 2010
The little white tube in my Jaccuzzi toilet comes disconnected with the pressure of the water and you have water all over the floor. Any solutions?
You have too much pressure coming through the line. Turn down the water supply pressure by turning down the knob on the supply tube so just enough water comes through to flush but not so much that is blows the tube out.
Mar 01, 2013 | Refrigerators
I have a saniflow for toilet and when flushed it makes a whirring noise and gradually goes to a loud crunching noise at this point i turn power supply off when turned back on its ok till next flush !p
find water pressure regulator. it will have a bolt coming out of the top with a nut at the base of it.loosen nut. while toilet is being flushed, adjust bolt till noise stops. turn bolt clockwise to adjust.
Dec 17, 2011 | Taylor Home
I have a thetford toilet in my caravan with electrical flush since the big freeze it makes a flush noise but despite being full will not flush
Try tapping on the opening in the bottom of the toilet, the valve that opens, with a broom handle while flushing to see if it has somhow gotten stuck. There is also a micro switch in the groove that the blade turn knob slids into, this could be bad as well as the pump may have been damaged, it is under the toilet roll holder. Here is a link to their repair site.
http://www.thetford-europe.com/web/show/id=51498/langid=42
If this info was useful a vote with the thumbs up would be greatly appreciated.
Jul 05, 2011 | Electronics - Others
After I flush the toilet, the motor continues to run and not stop. The only way to stop the motor is to kill the power to the unit. I was told the the float or float switch may be stuck. I was wondering...
Yeah most likely the float switch may be stuck in the on position. Remove the pump out the back of the toilet, pry open the lid using a flat head screwdriver, remove 2 or 3 screws from front and back of pump casing, remove the motor and pressure chamber out the top as one piece, place it on a work bench, the pressure chamber is the white casing where the power cord comes out the top. There is a black rubber membrane at the bottom of the pressure chamber, inspect it and make sure is not warped or that there are no solids build up at the bottom.
Feb 07, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflow dosnt allways come on when you flush
That can be a problem with the pressure chamber, the membrane might be warped or the micro switch may be defective. Open the lid and remove the motor and presure chamber. Inspect the unit for damages or any broken pieces. Check that the membrane is not warped. This can be tested manually by placing the motor on a work bench and putting pressure on the membrane to manually start the pump on and off. If parts are needed you can buy them through Saniflo directly. Their website is www.saniflo.com
Jul 13, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Our saniflo toilet is making a continous noise and no water is emptying and when flushing it is backing up into toilet as you will be aware is and has been very cold is this due to frozen pipe outside and...
It's a long time since I had the questionable pleasure of dealing with one of these... However, they are basically just a tank with a float-operated pump. Your continuous noise will be coming from the pump, and this is bad news not only because it means the tank is not emptying but also because these pumps are designed to operate in short bursts rather than continuously. So the first thing I recommend is: don't flush the toilet again until you've got the blockage sorted. Second: switch off the power to the unit (if it's wired in to a wall outlet without a switch, remove the fuse from the outlet). Third: locate the place on the outlet pipe where you think it may be frozen, wrap some rags around it and then pour hot water on it (the rags will help retain the heat). Remember, you are melting ice, so this may take some time and several applications to be effective. From time to time, switch the unit back on to see if it's now draining. Once you get it clear, you should lag all exposed pipe that may be liable to freeze. While the freeze continues, you may also like to consider flushing with a bucket of warm water rather than using the cold cistern! Good luck! P.S. I don't recommend using antifreeze.
Jan 08, 2010 | Saniflo & Saniplus& Macerator Pump
We just replaced out toilet because we had no flushing power on the old one. After cleaning the vent pipe and using a snake and putting on the new toilet, we still don't have any pressure when flushing...
its got a blocked down pipe lime scale will do this to you, the only way to sort it out is strip it out completly and give it a good clean, if that still failes to flush then its the flushing pump needing looking at,
Oct 25, 2009 | Cadet Manufacturing American Standard...
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
Saniplus motor (flushing noise) keeps repeating
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
Jan 28, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
