Question about Samsung SCX-4100 All-In-One Laser Printer
When i start print the message is shown on printer display :" pc dram is ng" so what is solution.
  • 360 Answers
Im didnt understand please telll paper jam is the case?
Posted on Aug 23, 2010
How to clear bizhub 163v memory
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings ?< ? ,< ? Quick Settings ? < ? >
3. The SERVICE MODE menu screen will appear.
11.10.2 RAM TEST
A. Use
• Write or read data to/from RAM memory to make sure of normal operation.
• When test finishes and everything is okay, it will display "RAM CHIP IS OK" and automatically clear DRAM.
After DRAM clear finish, LCD will display "DRAM IS CLEAR!."
B. Procedure
• Pressing the Menu/Select key will start the check.
• After approx. 30 seconds, "RAM CHIP IS OK" will appear.
Does not work have a tech come out
May 16, 2016 | Konica Minolta bizhub Office Equipment &...
Wireless printer X4550 has stopped printing. An XL would not print and won't delete from the print queue thus nothing else can be printed. Status is "deleting"
Starting the Installation Log on to the PC as Local Administrator.
Windows 2000: Double-click on the My Computer icon on the desktop. Double-click to open the Control Panel window and then double-click on the icon labelled Printers. Double-click on Add Printer to start the Add Printer Wizard. The dialog below will be displayed.
Windows XP: From the Start menu, select the option Printers and Faxes. Click on the task Add a Printer to start the Add Printer Wizard. The dialog below will be displayed.
pwiz1.jpg Click on the Next button to display the dialog shown below. Ignore the instructions in this particular dialog box because they are incorrect.
pwiz2.jpg The Wizard provides installation options for local and network printers. Select the option Local printer if you are installing drivers for a personal printer (using a USB, serial or parallel connection). If the option Automatically detect my printer is selected, you will see the warning message below.
pwiz2a.jpg If you are installing drivers for a TCP/IP LAN printer, you should also select the option Local printer. For a LAN printer, always ensure that the Automatically detect my printer option is not selected.
The Add Printer Wizard will display the dialog below so that you can specify which port (connector) the printer uses.
pwiz3.jpg For a personal printer, ensure that the button for Use the following port is selected. From the list, select the Local Port to be used -- this is normally the parallel port, LPT1. If you are unsure, please refer to the documentation supplied with your printer or check which type of cable is being used.
thanking u for using fixya
Jul 07, 2008 | Lexmark Office Equipment & Supplies
The printer is displaying error: B0605 on the screen
HI............
Issue Description: Print cannot boot up into ready state with an error message shown on printer control panel. The error messages include ERROR: B0601/ B0602/ B0603/ B0604/ B0605. Root Cause: Firmware crashes. Note: Inappropriate behavior may cause firmware crash. For example, a printer is turned off when critical firmware update is undergoing. Solution: Firmware Update Utility.
There are two use cases when encountering the issue: Instructions for Use case 1: driver is previously installed on PC
  1. Place printer in bootcode mode.
    1. Hold down the Cancel and OK buttons.
    2. Power on printer.
    3. Continue to hold down buttons until control panel dislpays Hewlett- Packard on the first line and Bootcode on the second line.
  2. c01688132.jpg Please observe the printer control panel and verify Downloading Update Data is displayed on control panel followed by Programming App Flash; please wait for upgrade utility to finish. Printer would be restarted automatically and the control panel display would show Ready .
Then the firmware is now successfully recovered. Instructions for use case 2: driver is NOT previously installed
    1. Insert printer installation CD.
    2. In Windows OS, please go to Start , Settings , Printers and Faxes .
    3. Click Add a printer to start Add Printer Wizard as shown blow and click on Next button. c01688133.jpg
    4. Check Local printer attached to this computer box; uncheck Automatically detect and Install my Plug and Play printer box and click on Next button. c01688134.jpg
    5. Select FILE:(Print to File) in the Use the following port: dropdown list and click on Next button. c01688135.jpg
    7. Browse to the CD drive in which the printer installation CD is inserted previously and click OK button. c01688137.jpg c01688138.jpg
    8. Highlight the HP LaserJet P2050 Series PCL 6 found in the printer installation CD and click on Next button. c01688138.jpg
    9. Specify the Printer name and click on Next button.
    10. Select No for Do you want to print a test page? and click on Next . c01688139.jpg
    11. Click the Finish button and allow driver to install as shown below. c01688140.jpg
    12. Verify printer is listed in Printer and Faxes window as shown below: c01688141.jpg
  1. Place P2055 in boot code mode:
    3. Continue to hold down buttons until control panel dislpays Hewlett-Packard on the first line and Bootcode on the second line Printer is now in bootcode mode.
  2. In the Printer and Faxes window, right click on the HP LaserJet P2050 Series PCL6 icon and select Properties .
  3. Click the Ports tab and view the USB ports as shown below.
    NOTE: If more than one (USB001) please take note of all listed ports, as other installed printers may have USB ports (USB002, USB003, etc). c01688142.jpg
  4. Close Properties window.
  5. Plug in USB cable from to PC
  6. The Found New Hardware Wizard will pop up, and tje printer USB enumeration will happen.
  7. Open printer properties and select Ports tab again.
  8. In ports tab, tick the correct port that the HP LaserJet P2050 series printer is enumerated on and click OK . c01688143.jpg
  9. Click Cancel on Found New Hardware wizard window.
    NOTE: Not the driver is installed and it is pointed to correct USB port.
  10. Run HP LJ P2055 Firmware Update Utility.
Sep 21, 2011 | Computers & Internet
My hp deskjet f2280 printer does not photocopy. It displays an "E" error message, always.
I have got exactly the same problem. E shown. F2280 does not copy. Otherwise it prints and scan request from PC working.
I do hope, somebody reads the question, understands what is said and has a solution. Thanks in advance. AOS
Jan 23, 2011 | HP DeskJet F380 All-In-One Printer
IR3025 can not print, Status NG
Try to enter service mode: * 2 8 *
COPIER
FUNCTION
CLEAR
ALL
OK
TURN OFF AND ON
NOTICE: WHEN YOU CLEAR ALL THAT MEANS THAT YOU WILL HAVE TO INSERT ALL SETTINGS THAT YOU MADE, LIKE IP, GATEWAY, EMAIL FOR SCANN...
May 06, 2010 | Canon ImageRunner 3025 Black and White...
Memory received but i am not able to received fax
Please change the toner and feed the papers. It will print all the faxes recd in memory.
Nov 05, 2009 | Samsung SCX 4521F All-In-One Laser Printer
My Xerox Phaser 6110MFP got error "Internal Error WER OFF/ON DRAM-FUNC.C 58 R". Cannot get solution from any sites. Can't use printer. Please help, thanks. weichen81@msn.com
DRAM TEST
Use this feature to test the machine's DRAM. The result appears in the LCD display.
If all memory is working normally, the LCD shows << O K >>
Jul 04, 2009 | Samsung CLX 3160fn All-In-One Printer
Error in printing
there is a printer options at control panel, try to see if the setting is printing immediately,...
Jun 17, 2009 | Epson laser Printer EPL-6200L Laser
Fargo printer display DRAM MEMORY BAD
the memory module will need to be replaced on that unit, I believe on that unit it is replaceable. I have worked on these before. we are an authorize service center forit.
Jan 10, 2009 | Fargo Pro L ID Thermal Printer
Lexmark 5400 series
Problem: Lexmark cannot retrieve applications list
I have the Lexmark X3550 with the WiFi option board installed (makes it same as the model X4550) and get the “cannot retrieve applications list” message on one of the five computers connected to my router (Linlsys WRT54G V8) and using wireless printing and scanning. Just like everyone else with a similar Lexmark WiFi printer/scanner, I can print wireless, but cannot get the wireless scanner to work on one of my PCs.
The fix, in my case, was to change the Lexmark network name as follows.
1. Launch Lexmark Imaging Studio.
2. Right-Click on “View or change network settings”.
3. Enter a new network name in the first box shown. (This box contained the correct network name for my PC, but another name was needed to make the scanner work. I simply added “-lex” at the end of the current network name.)
4. Right-Click OK. You should return to the Imaging Studio screen.
5. Close the Lexmark Imaging Studio window. (The tray icon should remain at the screen lower right.)
6. On the printer, press the Scan Mode button.
7. On the printer’s display screen, select the Computer Name that you entered for the new network name. Just use the arrow buttons until the exact name is shown.
8. Press the Check button. The display screen should show “Downloading Applications List”. Within about 10 seconds the message should change to “ *Scan to Computer ”. Wireless scanning should now work.
9.. Press the Start Color or Start Black button. “Requesting Scan” will be shown. After a few seconds scanning will start. The process is a bit slow.
10. After a while you may see an empty small Lexmark window onscreen. Later, the Lexmark Imaging Studio will appear onscreen, then change to show many options and features. An image of the scanned item will appear in a Lexmark window. Save and/or edit the image. Another scan can be done by pressing the printer’s Check button again. Be sure the correct computer name is shown on the printer’s display.
That’s it. A new computer name was the solution. Your PC and printer may require a restart (power off) after changing the “computer name”.
Regards, Fbyrd
Mar 12, 2008 | HP PSC 2210 All-In-One InkJet Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
35 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
