Question about Westinghouse Refrigerators
About Westinghouse WSE697OSA fridge with ice and water dispeser delivered, but I am disapointed with the quantity of ice it makes. It does not keep up to our household demand. There are only three of us. It was supposed to free up fridge space, and not having to store water bottles in the fridge or ice in the freezer. Servce agents replaced the icemaker but it doesn't appear to be any better. I am very disapointed in the performance so far, and we haven't hit hot water yet.
HVACRH20
  • 237 Answers
SOURCE: icemaker is not freezing ice, freezer not freezing food,
The ice maker won't work if the freezer is warmer than 17 degrees so that's not an issue till you get the freezer cold again. I would guess that your unit is stuck in the defrost cycle. This could be the defrost timer failing. See if you can find the defrost timer in your unit and advance it by hand if possible. http://www.partselect.com/PartSearchResults.aspx?modelnum=jcd2295hes&mfgmodelnum=&fkmfgid=1&hint=defrost
Posted on Dec 04, 2006
  • 92 Answers
SOURCE: ice maker not working
make sure its turned on check the wire connector is seated and check to make sure there is nothing jambed in the tray if all that is ok call for service
Posted on Feb 10, 2008
SOURCE: water leaking inside freezer ice maker
just fix it.
Posted on Apr 26, 2008
huuum
  • 750 Answers
SOURCE: Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Posted on Oct 12, 2008
  • 57 Answers
SOURCE: Icemaker doesn't work
sounds to me like you did not get the ice holder is not in right, I would remove it and install it again. maybe a few times if I had to. If your water dispenser is working your water supply is good. You may also have to wait a day to get it to work right the ice maker will not fill until the temp of the freezer gets down. Also make sure the full bin arm is down. hope this helps.
Posted on Oct 20, 2008
The ice maker is making ice but when we push the dispeser from the outside it only shoots out water and no ice. What is the problem?
your dispenser will only do one or the other??... I my be wrong, but I have never seen one dispense water and ice at the same time???
Jul 11, 2017 | Refrigerators
Have replaced the 3part inlet water valve for our fridge freezer. Water is working fine,but still not making ice.
Check the ice bin level arm (also the ice maker on/off switch) is in the down position. It senses when the ice bin is full and turns off the ice maker until some ice in the bin gets used. It can also be lifted into the up position to turn the ice maker off.
Mar 07, 2017 | Westinghouse Refrigerators
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
No wate coming out the dispeser
The plastic water resivoir in the fridge compartment is frozen. Need to locate the resivoir which is at the bottom of the fridge and by using a hairdrier, warm the plastic resivoir for about 6 minuites. Suggest you turn the fridge off while doing this. retry and dispence water.
Jun 06, 2010 | Samsung 26.1 Cu. Ft. Side-by-Side...
Ice maker not working, no water or ice dispensed.
Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
Oct 13, 2009 | Westinghouse Refrigerators
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Water dispenser
wow that's agood one!!!! theres a short for sure, just a matter of where. somehow your energizing both sides of water valve at once, sounds as if it would be behind the dispensor, at the switches. would remove the dispensor cover and have a look for a bad switch or exposed wire
Mar 08, 2008 | Refrigerators
Ice maker broken
check to make sure the arm or what ever controls the cubes isn't stuck closed or the inlet to the maker isnt' got some restriction
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
125 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
