Question about ASUS A8V-E Deluxe Motherboard
I am slowly rebuilding my computer. When I nearly got it finished, and turned it on, it came up with "Windows Was Not Found". Knowing what to do, I turned everything off, unplugged it properly, and installed my new hard drive (with XP on it). I put everything back together, turned it on, but nothing happened. I turned it off, then on again, this time with the case open to see if any lights came on. The only thing that seems to be working, now, is a small LED on the edge away from the RAM and CPU. Hasnt worked since. I have tried a different Power Supply, but it still hasnt worked! Also, I have tried a different graphics card from a friend, new RAM, different HDD, and I have unplugged all the un-used power cords coming from the PSU (just incase they draw unnecessary power? Just a precaution). Any help?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Check for motherboard. use only 3 parts:
Connect your motherboard to PSU and see, if any LED light comes from motherboard. If LED is on, then try to turn motherboard on and see if cooler works.
Are case wires (power +, power -, hdd +, hdd -, reset+, reset -, power led+, power led - and speaker wire ) connected correctly?
Those wires look like this:
I am slowly rebuilding my computer. When I nearly - front-panel-headers-nsatmeh50lx5u1woeaeqllmn-4-0.jpgThis image is just reference.
If the power wire (sometimes called POWER SW) is not connected correctly, when you press the power button of case, PC just won't turn on.
If PC turns on and CPU fan spins, then try to add RAM, Graphics card and try again.
Next step is to hear BEEP sound. One short beep sound is normal, anything else is not normal and indicates the problem of the specific hardware according to the sound code. Sound code is BIOS dependent. In case ASUS A8V-E Deluxe, it is Award BIOS. Check below for Award BIOS beep codes
1 long, 2 shortIndicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
1 long, 3 shortVideo card not detected __ (reseat video card) or bad video card
Beeps repeating endlessly __ RAM problem.
Repeated high frequency beeps while PC is running __Overheating processor (CPU)
Repeated beeps alternating high & low frequency ___Issue with the processor (CPU), possibly damaged
Posted on Mar 17, 2017
  • 849 Answers
SOURCE: asus p5p800 motherboard
seem power supply fault, because some times, it looks that power going on, it is not giving proper voltage to motherboard. check other power supply.
Posted on Nov 21, 2008
  • 1027 Answers
SOURCE: computer not functioning
Sorry, but looks like the main board is dead (or the main CPU)
The minimum is to have the CPU and RAM installed, so the bios can be accessed.
Posted on Apr 18, 2009
SOURCE: ASUS M2N-E SLi Motherboard No Graphics
I have the same board (M2N-SLI) with a BFG 9800 GTX with no video either. I have the card in the black slot and I have 2 mem sticks in the yellow. Shouldn't make a difference if I'm using a monitor not an LCD right? Everything spins up for me too, hard drive, vid card has power, CPU fan is on, post (green) light is on.
Posted on Sep 25, 2009
  • 206 Answers
SOURCE: new build pc no boot... black screen
Try to remove the battery from the MB, and next time you try to install WIN XP, when you are asked how to format your drive, chose quick NTFS formatting; disable floppy drive in BIOS, because it might try to boot from it (and I suppose you don't have one), and in boot sequence (BOOT DEVICE PRIORITY) set cd-dvd as first, and HDD as second, and turn off any other device as bootable
Posted on Nov 17, 2009
  • 105 Answers
SOURCE: My husband recently built a
Hi, the thing to do here is to narrow down what could be causing the problem, initial suspects would be the RAM chips. If you have known working ones you can try in it, try these, if not, try without one, then swap them over, or even try without both.
Also, remove any components that aren't strictly necessary, i.e. hard drives & cables, cd-rom/dvd drives, extra PCI cards,network cards etc
Another suspect may be just a loose connection, try taking everything out, re-seating it. Again, pay particular attention to the RAM chips.
It could possibly even be a faulty processor, have you another you could try? Try taking it out and re-seating it.
Posted on Apr 12, 2011
1999 Cheverolet silverado reverse slowly went out
rebuild time, when they go it usually has a broken reverse band ..
Mar 30, 2014 | 1999 Chevrolet Silverado 1500
My computer has a virus
Not knowing what operationg system you have on your computer, XP, Vista or Windows 7, I would recommend your go the link I have provided below by copying and pasteing into your web browser to go the Microsoft Security Essentials.
Dowload and install the software. After the installation, it will go out for updates and do a fast scan of your computer for virus problms. Abort the fast scan and then select a full scan. Let it finish and if it finds problems go to history and it will display what has been found and what it did about if.
Good Luck
Aug 14, 2011 | Microsoft Windows XP Professional With...
Air tends to leak near trigger of my senco sls15 1/4" crown stapler . how can i stop it?
You have worn or broken o-rings/seals inside the gun. You need a Senco repair kit YK0393. Senco doesn't make them any more but there are still a few to be found on the internet. If you can't find one, go to the Senco webpage, find the parts breakdown for your gun and order all of the o-rings, seals and gaskets and rebuild your gun.
Feb 09, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
T42 gets message"NTLDR" not available. Tried to
Don't try loading windows with out fixing the NTLDR...Try this simple steps in recovery console,
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
  • Then rebuild the boot configuration boot.ini file by
    Attrib -H -R -S C:\boot.ini (if not found skip the next line)
    DEL C:\boot.ini
    BootCfg /Rebuild
    Do not use the repair option in the recovery console.
    Or, if you can get into XP, even safe mode, you can arrange to bypass the
    password by the following registry change:
    Click on Start then click run and type Regedit. Navigate to the key mentioned below,
    Set the DWORD Security Level value to 1
Hope this helps
Dec 27, 2010 | IBM ThinkPad T42 Notebook
There are 304 registry errors on my Computer. How can I repair it by online? My computer several time shows Blue Screen. When running System Registry Booster it identifies 304 registry errors and indicates...
Installation CD will not solve UNLESS you do a complete rebuild of the system.
You can subscribe to one of the regitry cleaners that scan and then REPAIR the errors. I have found it worth it to do this. Sometimes you need to run the scanner/cleaner several times to clear all the errors.
Jan 01, 2010 | Microsoft Windows XP Professional With...
Sir i have a problem with laptop,its effected from a.exe do i remove it,please help.i am usin gxp {profesional}
You will have to try a bunch of different software to get rid of this. Let's start you off from the top.
ESET NOD32 Antivirus.
Spybot Search & Destroy. (When installing Spybot, make sure to uncheck TeaTimer.exe. In other words, don't install it!)
AVG Anti-Rootkit Free.
You will need to download each utility. After installing them, restart your computer. After the restart, open up NOD32 Anitvirus and update its security definitions file. After it has been updated, perform an in-depth scan on your entire computer.
After NOD finishes, exit the utility and open Malwarebytes. Update Malwarebytes' security definition files. Afterward run a full scan on your entire computer. After the scan finishes, remove anything found (restart if necessary).
After Malwarebytes finishes, open up Ad-Aware. Update Ad-Aware's security definition files. Afterward run a full scan. If anything is found, remove it and if necessary, restart your computer.
After Ad-Aware finishes, open up Spybot Search & Destroy. Update Spybot's files then exit Spybot. Now open up Spybot again and select the category, "Immunize." After the automatic scan finishes, select, "Immunize" at the top of the aplication. After immunization is complete, exit Spybot. Now open up Spybot, again. After Spybot loads run the scanner (Press, "Check for Problems"). After the scan finishes, remove anything found then restart if necessary.
After Spybot finishes, open up AVG Anti-Rootkit Free. After the application finishes loading, perform an in-depth scan of all hard-drives. If anything is found, remove it then restart your computer.
If the virus remains after following the steps above you will have to get your computer repaired as it only gets trickier from here.
Let me know how it turns out for you. Don't hesitate to let me know if you need any more assistance.
Apr 25, 2009 | Microsoft Windows XP Professional
You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
  • Restart the computer.
  • Just after the POST diagnostics and memory count, start pressing the F8 key
  • On the Startup Menu, choose Safe Mode
or you may use the system configuration Utility Method.
  • While in Normal mode, Close all programs.
  • Click Start, Run and type MSCONFIG in the box and click OK
  • In the System Configuration Utility, on the General Tab, click the Advanced Button
  • In the Advanced Troubleshooting Settings dialog box, check Enable Startup Menu. Click OK. Click OK again when the System Configuration Utility reappears.
  • You will be prompted to restart the computer. Click Yes. The computer will restart in Safe mode.
  • When you are finished with troubleshooting in Safe mode, open MSCONFIG again and uncheck "Enable Start-up Menu." under the Advanced Menu, then click OK and restart your computer
Windows Xp:
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
  • Close all open programs.
  • The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
  • The computer restarts in Safe mode.
  • Perform the troubleshooting steps for which you are using Safe Mode.
    When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer
Windows as part of a multiboot system
Use this method ONLY if you have multiple operating systems installed on your computer.
  • When the Boot loader menu (list of the available operating systems) appears, use the arrow keys on the keyboard to select the version Windows what you want
  • Press Enter, and then immediately begin tapping the F8 key. The Windows Advanced Options menu appears.
  • Scroll to and select the Safe mode menu item , and then press Enter.
Windows Vista:
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 20, 2008 | Computers & Internet
You need to use the Recovery Tool from Creative's website at
Creative Zen
Try another PC or another USB port
Make sure the hold/lock is not engaged
Check for firmware update on Creative's website
Get Recovery Tool from Creative
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If all else fails, check with this guy:
Creative Zen – Formatting
Step by step instructions for formatting a player
1. Detach the player from the PC if it is connected, and turn off the player.
2. Press and hold the Play button while powering on the player.
3. When the player displays the Creative logo, release the Play button
4. Select Format (All) and select Yes to format the player.
5. After the player has finished formatting, select Reboot.
6. Re-transfer the tracks to the player.
-Tha Mp3 Doctor
Sep 23, 2008 | Creative Labs Zen Digital Media Player
ASUS A8V-E Deluxe Motherboard Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
