Question about Toys
Fitting instructions for a Babydan flexi fit safety gate
2 Suggested Answers
jesiquiux
  • 168 Answers
SOURCE: babydan fitting instructions
To be able to log into Babydan media database, you need to have user access: LOGIN
I hope this helps.
Posted on Oct 02, 2010
What is a pressure mounted safety gate?
These gates work by opening the date so they are wide and can fit a doorway. It then locks in the position with each side pressing against each side of the door frame. These gates are widely used becuase they are not expensive and they are portable.
Jan 29, 2013 | Baby Gear
Hi I have a Safety 1st pressure fit gate. I just
contact the manufacturer, there should be a customer service number on the package someplace
Jun 05, 2017 | Baby Care
My compressor does not hold pressure, no leaks that I am aware of. When I press are gun pressure goes way down.
May just be bad pressure regulator. Easy test. Let out all the air from the compressor. Find and remove the safety valve. Install a tee fitting where safety was installed and reinstall safety and a quick fitting at the other port. Now let compressor fill and shut off. Connect gun to temporary quick fitting for test. Replace the regulator as needed (you can install a generic pressure regulator at the temp. fitting for fast repair). You do not have to uninstall the test fitting.
Jul 01, 2011 | Air Tools & Compressors
Hi! We've just bought our son the playmobil castle 4866 and for some reason we can't seem to get it assembled correctly. When we follow the instructions, the walls, which are supposed to fit on either...
Here are instructions to building castle 4866,
http://www.playmofriends.com/forum/index.php?topic=5897.45
Also if you are having problems getting the gate to connect to the walls here is the fix
The red circles indicate that there is no proper fitting...after close inspection and going through the instructions again, I found out that I need to place the nortwestern corner, green circled, at a different system -x hole line.....
Dec 30, 2010 | Playmobil Toys
How do I purchase new hinges for the baby gate?
Looks like you have to call the company.
I need to replace hinges for the safety 1st Perfect Fit gate and will do soon. If I remember, I'll provide an update.
Dec 27, 2010 | Safety 1st Perfect Fit Gate Fits 30" 42"...
Babydan fitting instructions
I hope this helps.
Oct 02, 2010 | Toys
Need to know if my cooker is a bayonet fitting
the bayonet fitting is on the end of the gas pipe that plugs into the gas main. look at the back of your cooker follow the black pipe you will see a brass end that fit to the solid gas pipe if you have a ring on the end of you flexible pipe that you can push in slightly and turn to disconnect you have a bayonet. its not the cooker that is a bayonet but the flexy pipe that is connected to your cooker. you can add one if one not fitted
Feb 02, 2010 | Belling Solitaire G755 Gas Kitchen Range
PLUMBING>FITTING FLEXI TAP CONNECTORS TO BATH
NO PROBLEM USING FLEXIBLE HOSES. JUST ENSURE THEY ARE NOT KINKED WHEN INSTALLING
Oct 13, 2009 | Home
Low water flow
buught sink taps same problem do they have flexy conectors with them. my problem was as they are american hot @ cold water suply are maines fed so hole in bottom of taps [or in flexy pipes are too small
May 17, 2009 | Danze D302521 Antioch Roman Tub Faucet...
How do you remove the plastic end fitted to the flexible hose
Not necessarily. Some Dyson models have an all inclusive flexi hose which attaches to the handle spine. Check EBay for replacement flexi hoses - UK has many sellers - or handles which have the metal pole and the flexi tube attached.
Alternatively take off the flexi hose from the bottom rear of the Dyson - it can come out via a press in lock release but it may take some time to do this. Once that is done the flexi hose should come down freely from the metal tube. If it doesnt then you may need to consider both replacements.
Dont forget to rate, thanks.
May 25, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Toys Logo
165 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
