44-pin hard-drive ok for an Acer Aspire 51003583 Notebook PC
Yes, this is for a notebook PC.
I don't have immediate access to it and I'm concerned if the
internal connector will be ok for a 44-pin hard-drive replacement.
  • 13,433 Answers
Most likely it will be ok, unless the laptop uses SATA as the connector.
Posted on May 04, 2008
Can I take a working SATA ACER notebook HD and put it in an ACER with 44 pin IDE?
Just check whether your hard disk is in good condition., what is the health percentage., It has any bad sector or weak sector,. before changing.,..(because if u use convertor it should work)
use harddiskscential for performance of your hard disk
SATA to IDE adapters any good
http://www.hdsentinel.com/ SATA to IDE Adapter Drive Not Detected in BIOS
Jun 05, 2015 | Acer Computers & Internet
Don't know how much hard drive acer 5050-3371 has
I have an ACER ASPIRE ONE. Try the following; 1- click start. 2. click computer. If it doesn't display how many GB you have left on your hard drive, click computer . I'm just a rookie, so good luck.
Apr 14, 2012 | Acer Aspire 5050-3371 Notebook
I have an Acer Aspire 6530 when it's turned on the screen stays white and blank. There is a burning plastic smell.
I would say a loose connection to the display I would immediately turn it off. A "burning plastic" smell could be caused by a wire grounding out somewhere.
Mar 08, 2011 | Acer Aspire 6530-5143 Notebook PC
I had a problem with my laptop. i took laptop to dad he changed my hard driver soo now i got toshiba in acer aspire notebook. it was ok after that and now wen i load up my notebook my laptop like to shut...
oh boy if i am guessing it right abt the error msg which is %90 yes, ur hard drive gone for a toss .try connecting it to another pc/laptop to check if it is detected. if not i am afraid u got to buy a new one...
i hope its under warranty dude..
Dec 27, 2010 | Acer Aspire One D150-1587 Netbook
I would like to replace the hard drive on my Acer Aspire 3004 notebook. The current hard drive is failing and I would like to install one that I took from another Acer computer that I threw away. The hard...
Hello lakotalisa,
Q:Where are the access panels for the hard drive and the RAM?
A: See the Bottom of your notebook. Please refer the manual for more details
Q:Am I correct in saying that once I change hard drives the virus will go with the old one?
A: Yes, You are correct.
With regards
Pankaj
Sep 22, 2010 | Acer Aspire 3004LCi Notebook
Rebuilding Acer Aspire 3660
Acer Aspire (NoteBook) 3660 Series
Please see below for the Memory ( RAM ) upgrade options available for the Acer Aspire (NoteBook) 3660 Series.
Memory Details for the Acer Aspire (NoteBook) 3660 Series Standard Memory : 512MB (Removable) Maximum Memory : 2GB Total Memory Slots : 2 Memory Type : DDR2 667MHz (PC2-5300) 200-PIN SODIMM
Dec 28, 2009 | Computers & Internet
Aspire Notebook 5735-4774 won't display on external CRT monitor
If the video chip on the Aspire motherboard is OK then the image on the external monitor would be OK. If not then the video/motherboard is faulty.
To gain access to data on the hard disk, remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. The computer will see this as an external hard drive.
Alternately -
You can put the hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Dec 21, 2009 | Acer Aspire 5735 Notebook
Acer harddrive working also in other Acer notebooks?
You can physically install the drive in any laptop with the same type. They will either be SATA or IDE. However unless you have a nearly identical system which is unlikely after a few months of buying it the windows installation is not likely to work.
The better solution would be to stop in at your local computer store and purchase a 2.5" drive caddy and install the HDD into the caddy. That caddy will then work as an external HDD on any computer you purchase allowing you not only to access the files on it but also to backup any new data.
Chris
May 31, 2009 | Acer Aspire 5100 Notebook
Bad hard drive
puchase one vista cd/dvd and install no other option
Oct 28, 2008 | Acer Aspire 4520-5582 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
