Question about Sanyo DS19310 19" TV
I had just bought an old sanyo tv, it didnt come with the av connections, but when i seem to hook the vcr or the cable to the port in the back its not giving nothing but static..even on channels 3 and 4
  • 417 Answers
Hi, have someone watch the tv while you wiggle that connector around in the back while its hooked up to the vcr or cable is plugged in and channel on 3 or 4 see if you get any luck, use a little pressure to move the connector. This is a common problem. It will probably need to have the connector resoldered to the board.
jm
Posted on Aug 23, 2010
  • Jude Meredith
    Jude Meredith Aug 23, 2010
    if you can get it to come back to life while your putting pressure on it, try and find something to use as a wedge to hold it there, right in between the case of the tv and where the connector goes in.. like a toothpick, matchbook or something like that, sanyos are pretty good sets, good eye.
    jm
Hooking up old Sanyo box tv with old magnavox vcr
You need a TV cable though ANY cable might work. But definitively the only way to connect a VCR co a TV is through the antena setting TV to channel 3 or 4.
Even if you can't see it, all old TV sets must have an antena input.
If you can't find it, call a TV repairman, should help to make a connection.
Jul 03, 2016 | Sanyo Televison & Video
I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player...
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
Apr 19, 2010 | Televison & Video
I have an old sanyo TV with only one av how can i tune VCR into a
You don't need too! All you need to do is get one of these boxes and you can connect all to that one scart, plus record the freeview to your vcr. They are not expensive, I got mine from Amazon.
Apr 04, 2010 | Sanyo VHR-H531 VCR
IBM ThinkPad 380Z AV Hook up To Tv
From what I have been reading, the video card in the computer itself MUST support TV out. You can't just use a TV like a computer monitor...it won't work. Check the ads on eBay for those adapter cables and they will say: Check to make sure your video card supports TV out. Go back to eBay and search in the same general area for a computer video to TV adapter or converter box. DO NOT get it confused with the converter box for HDTV. They are about $25-$35 and you will still need the cable adapter you already have, plus another set of just the AV cables. Good luck. Please rate this if it was helpful.
Sep 26, 2008 | IBM ThinkPad 380ED
Hooking my dvd/vcr up to my television.
Easy Answer! connect to composite cabels to the ports underneath the words "DVD/VCR Out" for a Coaxial, use either the component ports or connect a coaxial cable from the port labled RF Out to the one on your television.
Aug 30, 2008 | Sanyo DVW-6100 DVD Player/VCR
CANT GET CABLE TV SIGNAL
When you hooked up the VCR or the Sat did you use patch cables? Sanyo had a lot of problems with tuners going bad. if you used patch cables you by pass the tuner so it will work
Apr 18, 2008 | Sanyo DS20425 20" TV
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Mar 04, 2008 | LG 42LC2D 42 in. LCD HDTV
I need help with my tv and dvd/vcr combo
Hmmmm...I dont understand exactly what you are saying, but it sounds like your TV doesnt have RCA ports and you want to hook up a newer DVD player that uses RCA ports. If you have only a cable port (silver threads with a hole sticking out of back) on TV and RCA ports on DVD player, you have to buy a converter. You can get one at Wal-Mart for 20-30 dollars. Or you can just update your TV which it sounds like you badly need to do! :)
Dec 24, 2007 | Sanyo DVW-7200 DVD/VCR
Connecting VCR/DVD combo
Put the Tv on Channel 3
Jul 11, 2007 | Sanyo DS25390 TV
Sanyo DS19310 19" TV Logo
53 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
