Question about Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer
F2 error code on my kenmore he4t washer - Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/2 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
He4t kenmore elite smartwash quietpak9. keeps flashing F2?
"F02" is a Long Drain error. This is an indication that there's an obstruction somewhere in the drainage system. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the bottom front edge of the lower toe panel directly below the door. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Mar 02, 2010 | Washing Machines
ERROR CODES ON MY WASHING MACHINE
join todays crowd!!! im in the same issue it is f2 error thatfollowedf suds error huh?
f2 is long drain issue after 8 minutes occurs anf the water valves to machine can be not fully iopoen; unplug ist
next keep off 2-5 minutes tpo clear memory
replug in
check drain hose not kimked
check drain pump inside is the next issue for prom is filled with foriegn objects that is known for this unit!!!! their a tech online kctech thats great try his answer online to use a shop vac and **** out any water in the inside and the hoes: and the drain pump inside the machine: see solution #6 may 2008 posted by washer gut in knasas that is eceptional to follow great day danw.
Mar 19, 2009 | Kenmore Elite 45986 Front Load Washer
Iget a f-11 trouble code on my kenmore elite he4t washer.
REplace your MCU. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem. Go onto kenmore.com and find your right washing machine and replace the part yourself. First try and take the wiring harness off and then reconnect it and see if the error code goes away if it doesnt then replace the part. Please Rate. Thank you
Feb 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore he4t washer shows f-11 error
F-11 // WILL THEN APPEAR FDL CODE DOOR LOCK LOCK FAILURE, F-11 COMMUNICATION ERROR REPLACE MAIN CONTROL,, JUST REPL 3 TODAY ....
Nov 28, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Getting fault code f14?
F14 = EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU.
If there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Oct 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
F Code for the Kenmore Elite he4t Front Load Washer (3 years old)
Hi! ricksmith
What is the first three digits of the model number.
The he4t I have reference to does not have a "F" code error. Most of the codes are two digit, PF, F1 to F9 etc.
You could try: Pressing Pause/Cancel two times to clear code. As well as unplug for 20 seconds. Do you have power fluctuations in your area.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite error code
possible electronics failure. my HE4t has completly gone dead at the control panel after displaying error codes. A class action law suite is in the works on the HE3t HE4t machines.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer Logo
302 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
