Question about Facebook Social Network
Has been block by server - Facebook Social Network
  • 70 Answers
Go to account setting and do your account block.
Posted on Aug 23, 2010
Hotmail pop and smp codes
  • POP server: pop3.live.com
  • POP server port: 995
  • POP SSL required? Yes
  • User name: Your Windows Live ID, for example yourname@hotmail.com
  • Password: The password you usually use to sign in to Hotmail or Windows Live
  • SMTP server: smtp.live.com
  • SMTP server port: 587
  • SMTP Authentication required? Yes (same as POP3 username and password)
  • SMTP TLS required? Yes
Aug 10, 2015 | Google Computers & Internet
HOW DO i BLOCK PORT 80
Port 80 is the web port. Whenever you look at a web page you are going to port 80 on the server. If you block port 80 then you won't see web pages. I am assuming it's outgoing traffic to web servers you wish to block. A standard router will have incoming port 80 blocked by default. You would OPEN port 80 if you had a web server at home.
Feb 22, 2015 | Apache Micro Peripherals Computers &...
I cannot retrieve my mails or send emails, what is it
do you have an internet connection ? what email program ?
Doing a little detective work can save you a lot of extra hassle. If you're having trouble sending email from clients like Outlook, Eudora and other POP3/IMAP software, please check the following issues:
Correct Passwords
Verify that all password information is correct.
We get many requests that simply turn out to be a password error.
When cutting and pasting be sure to watch out for extra spaces.
Mail Server (SMTP) is Offline
Your server could be running and serving both POP3/IMAP but not providing SMTP service. On many systems, the program responsible for POP3/IMAP is not the same as the one for
open an email click tools accounts mail then on the right select properties you should see your email adress then click on servers you will see
POP3 should have mail. with your provider ie: mail.bigpond.com
and outgoing mail the same mail.bigpond.com
SMTP. As a result, you may be able to check mail but not send.
Try restarting your server or email service from your control panel.
ISP Blocks
An increasing number of ISP's are blocking port 25, the port used to send email.
Many of the major ISP's, including NetZero, MSN, Earthlink, AT&T, Comcast and Verizon, block port 25 in an attempt to control spam. If your ISP blocks port 25, then you will be unable to send email out of your server.
This is not a server problem but a direct block by your ISP. We can often work around these blocks by configuring your mail server to listen to additional ports.
You can test if port 25 is blocked by using a telnet client to connect to port 25.
If you connect successfully to port 25, you will see your mail server's banner.
This will list some information about your mail server.
If you cannot connect to port 25, then either your mail server is down or your ISP has block port 25.
ISP blocks are becoming an increasing problem.
Generally, once password issues have been ruled out, sending email is all or none. If the mail server is down, no one will be able to send email.
ISP blocks will only impact those clients behind that ISP's network.
Server Load Throttling
Many SMTP servers will begin to reject email if server loads are too high.
If you have root access, you may want to login and run "uptime".
This will tell you your current load averages.
Many systems stop responding to email requests if loads exceed 12 for a five-minute period.
If the load does not decline to below 4 within a few minutes, then you may have a service performance issue.
SMTP Authentication
Most email servers use one of two mechanisms to determine if a user is permitted to send email.
The first method, "POP before SMTP", requires that the user first check their email before they can send.
If a user cannot check their email, then they will not be able to send.
Try restarting your POP3/IMAP server and testing again.
The second and preferred method is called SMTP Authentication.
This method should be used if your system supports it.
Current Ensim, Plesk and cPanel servers all support SMTP AUTH.
To use this feature, the user must check configure their email client to use authentication for sending mail. In Microsoft Outlook, there is a check box called "This server requires authentication."
That box should be checked.
hope this helps
Sep 17, 2012 | Dell Latitude D 600/610
I have tried using the Firefox way to view a blocked myspace profile but it doesn't work. I need to view a blocked myspace profile please help me.
If you're being blocked by your company's server or some public server, try going about it through proxy server... such as www.hidemyass.com.
Jul 18, 2011 | Televison & Video
Hold'em Message i could not connect to the server. The server may be down for maintenance. Your firewall may be blocking access to port 9339. .
Texas Hold'em Message
Connection Timeout.
Please email poker_customerservice@zynga.com if you cannot resolve this issue.
Feb 15, 2011 | Facebook Social Network
NMI ISSUED PRESS ESC TO TURN OFF NMI IN IBM SERVER
dear mugkifa ,
the above error indicates , a non maskable interrupt occurred in your server , there may be a change of malfunction of a hardware ,like add on cards
one more solution in ibm server is disablig the NMI interrupt by using jumper settings (inside motherboard)
see the below mentioned details , may differ with your server series please refer with series on http://www-947.ibm.com/support/entry/portal/docdisplay?brandind=5000008&lndocid=MIGR-5069937
System-board jumpers
The following illustration shows the switches and jumpers on the system board:
migr-5069937_2.gif Note: Any jumper blocks on the system board that are not shown in the illustration are reserved. The following table describes the function of each jumper block:
Jumper Settings CMOS jumper (JP3) Pins 1 and 2: Keep CMOS data (default)
Pins 2 and 3: Clear the CMOS data, which clears the power-on password and administrator password Boot block jumper (JP4) Pins 1 and 2: Normal (default)
Pins 2 and 3: Recover boot block NMI (non-maskable interrupt) switch (SW1) Normal (default): No NMI issued
The NMI button that is on the rear of server, connected to this switch, has been pressed: NMI issued
May 07, 2010 | IBM eserver xSeries 360 8686
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
So you verified ICMP traffic isn't blocked and it appears the servers allow the netBios traffic to pass.
On the client machine, check to make sure the windows print and file sharing is installed and the machine isn't blocking netBios traffic.
Make sure TCP ports 137,139, and 445 are open on the xp machine and any devices in between.
It's acting like the TCP data is being blocked by the client machine.
HTH,
-Aaron
Sep 28, 2009 | Microsoft Windows XP Professional
Im on uTUBE it kep sayin"Apache Server at www.youtube.com Port 80
you should block the messages they typed but don't block youtube because other people want to listen to mmusic and watch videos. Just block tha message such as bad messages.
May 20, 2009 | YouTube Videos
Kido is blocking antivirus updatetion , installation etc.
Dear Sir,
Go to http://xviruslab.blogspot.com, and download Quick Heal Total Security (PC Mobile Scan and Data Theft Protection, Anti Phishing) or Quick Heal Anti Virus Plus, mail me if you're facing any problem.
Thank you
Bye bye
keerthy
Mar 30, 2009 | HP ProLiant ML370 G5 Server
Facebook Social Network Logo
15 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
