Question about Toshiba e-STUDIO 352 Black and White Copier
How do I clear the message "time for maintenance" in the copier. Thanks
    Sniper:
  • 66 Answers
Go into (08) mode by holding 0 and 8 when turning on the copier. 251 is the number of copies until it displays that message and 252 is the count since last Preventative maintenance. Resetting 252 will clear the message or putting 251 higher than the value of 252 will clear it as well.
Posted on Aug 23, 2010
HOW I WILL GO IN SERVICE MODE OF A PRINTER
Clearing the Maintenance Count and Service Message: HP LaserJets servicepin.jpg
If the display panel on your HP LaserJet reads "Perform Printer Maintenance", "Perform User Maintenance", "Maintenance Kit Low", "Maintenance Kit Very Low", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count.
Oct 31, 2014 | Ricoh Aficio SP C410DN Laser Printer
Toshiba 2330C periodic maintenance code 00FF?
machine ON .....0+8
code is ....252.... press start button
value input is......0
press Enter Button
time for periodic maintenance is clear.
Apr 01, 2014 | Toshiba E-studio 2330c 2830c Color...
Time for maintenance message
As your counter reading is above 1.5 k thats why its coming. clear it by maintenance mode by pressing 1087 1087 then go to U251 to clear it
Mar 12, 2014 | Kyocera Mita KM-1650 All-In-One Printer
How to reset hp laserjet m5035 maintenance kit problem
When page count approaches 200,000 pages printed, the device alerts to order a maintenance kit. The message can be temporarily cleared by using the Clear Maintenance Message item on the Resets submenu under Administration. When the page count reaches 200,000, the message can no longer be cleared and the maintenance kit must be installed. To check the number of pages that the device has printed since new maintenance-kit components were installed, print either a configuration page or a supplies-status page. The print-engine maintenance kit includes the following items:
  • Fuser
  • Rollers (transfer, feed and separation)
  • Separation pads
  • Installation instructions
Mar 02, 2011 | Office Equipment & Supplies
Maintenance message kept appearing but could still use machine. With info from your site, I think I cleared it. However, we keep getting a message that there is a paper jam (Jam 50). Could find nothing...
Maintenance message is setted by the technician, the numbers of copies that you can make with the same drum is limitted by the technician, (100k) if you reach this limit the maintenance message appears, you have to replace the maintenance kit (the opc drum, transfert corona, main corona) to avoid the bad quality copy. if you need to work with the machine you have to call the technician he can increase the counter limit to clear the warning message.
Dec 27, 2010 | Copystar CS-2030 Copier
My brother printer DCP135C have to following error message how to clear it "clean unable 46 see troubleshooting and routine maintenance chapter to user's guide"
Try to reset DCP printers without numeric keypad.
Follow this:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Don't forget to vote Thanks!!!
Oct 29, 2010 | Brother DCP 130C All-In-One InkJet Printer
"Time for periodic maintenance"
Apr 11, 2010 | Toshiba e-Studio 232 Black and White...
What is "Maintenance required. Code: AA"
Maintenance timing display The message of maintenance execution timing is displayed when each counter reaches the set value. The relationship between the messages and the counters is shown blow. Maintenance counter AA WhenThe maintenance counters (both of total and color) reaches 90% of the set value of SIM21-1 (When the setting of SIM26-38 is ?print stop?). When The maintenance counters (both of total and color) reaches the set value of SIM21-1 (When the setting of SIM26-38 is ?print allowing?). Enable ? After completion of the maintenance, execute SIM 24-4 (Maintenance counters (total, color) clear).
Aug 29, 2009 | Sharp MX-2700N Color Copier
Ricoh ap4510 - Maintenance Kit Issue
For the message to be cleared you should enter the service menu and reset the replaced elements
Jul 28, 2008 | Ricoh Aficio AP4510 Laser Printer
Toshiba e-STUDIO 352 Black and White Copier Logo
411 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
