Question about Intel Computers & Internet
I have d845epi motherboard my pc don't power on by press pwr key but green led is on in motherboard
  • 92 Answers
Hi, first, open your computer case then look at the few cords that come from the front of your compute these are the button and front led cords follow them to the motherboard remove them and put them back in EXACTLY as they were close the case and start the pc! Hope it works!!!
Posted on Aug 23, 2010
  • 724 Answers
Does the keyboard have a cd with drivers for these options?
How can i correct the front panel connections
your motherboard has three sockets for the front panel connection:
-USB socket, to connect any front usb ports you might have
-AUDIO socket, to connect speaker/microphone socket on the front of your case
-FRONTPANEL socket, where are connected the turn on/reset buttons, the ide/power leds and the buzzer. To connect all the pin in the right way, refer to the attached picturefranzer_2.jpg
Hope it helped,
Franz
Mar 02, 2011 | Gigabyte GA-8SMML Motherboard
I try to connect my ECS Motherboard one again but
you may have misplaced the power switch connections which come from front pane to the mother board
there are many of them like pwr switch, reset switch
hdd led etc
check *********** board it will be indicated where to connect the pwr switch pwr led etc
May 07, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
E-Machine PC with only a green LED on MB on Boot attempt
We have repaired many of these systems. The board was damaged when the power supply shorted. You can get replacement motherboards at www.barebonekit.net click on the link on the left side for motherboards and look for Emachine.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
No power up. green led on broad is on and unit
If the connector is integrated in the motherboard, the entire motherboard needs to be replaced. You can check with some local tech shops to see if the connector unit can only be repaired
Jul 03, 2009 | Computers & Internet
Need Diagram for the pwr,reset,pwr led,hdd led speaker connections on the motherboard. Model p5s 800-vm.
Hi there.
On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for using FixYa!!
May 27, 2009 | ASUS Computers & Internet
NO BEEP, NO DISPLAY EVEN REMOVING OF RAM.
are you using socket 478 motherboard or socket lg775 motherboard? if lg775 mobo you using try to remove the cpu heat sink and put it back again make you put correctly lock it perfectly and try to switch it on
Mar 12, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
My pc won't power on
Sometimes a defective / uder rated power supply is causing this. Defective power supply cannot provide the required load leaving your motherboard on standby mode (led green light) Try and check this first by replacing the power supply . Memory is another cause so if you also have spare you can run tests.
Jun 23, 2008 | Intel Desktop Board D845EPI Motherboard
Emachine T2742 MB D845EPI/D845GVSR
The diagram for that 9 pin J9G1 is alongside the CMOS battery.
Dec 25, 2007 | Intel Desktop Board D845EPIL Motherboard
Computers & Internet Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
