Question about Gaggia Titanium Espresso Machine
We have a five year old Gaggia Titanium regularly descaled. In recent weeks the flow of coffee has considerably slowed to a drip and we now get a message saying 'Brew Unit Missing'. The machine also now does not 'Rinse' and sometimes does not dispense coffee at all. What repair is required as we have done nothing at present.
    President:
  • 1,618 Answers
Remove the brew unit, find the 2 screws above the top shower the connects the discharge tube to spout. Remove screws and carefully remove spring and ball some have a plastic seat at end of spring. Clean tube make sure there is no coffee grounds blocking tube, reassemble and test.
Posted on Aug 24, 2010
Gaggia titanium coffee slow coming out of machine
Not sure it will work for you but Our Bunn has a flex wire to run thru the tube weekly , and if we do not clean that tube it might take 20 minutes to make a pot where when cleaned it does 12 cups in 3 minute
Nov 26, 2015 | Gaggia Titanium Espresso Machine
Why wont it switch on?
Check the 2-pole circuit breaker on the left side. You have to remove the back by removing 2 screws. Use a multimeter, test for continuity over both poles.
My ~8 year old Gaggia Titanium Plus was dead one morning.
I checked the circuit breaker and one of the two poles were bad.
I replaced the C.B. and all was fine :-)
Oct 06, 2015 | Gaggia Titanium Espresso Machine
Low flow, pump starts normal and within a few second becomes quiete
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
Jul 06, 2017 | Gaggia Baby Coffee Makers & Espresso...
Gaggia Titanium - can't get it to move beyond 'Ventilate.' This started as a problem with extremely slow coffee output. We've been good about de-scaling but brought it into a repair place who cleaned it...
Select "Hot Water" and open the steam valve. Let it pump water out the steamer for awhile. It usually clears right away but may need to pump a lot of water to clear the error.
If you aren't able to get any water coming out the steam nozzle, you may need to prime the pump with the little squeezy tool they gave you with the machine - or you can use a turkey baster. Mainly you are trying to get water up into the pump to prime it (get the air out of the pump) so it can pump water instead air.
Oct 09, 2010 | Gaggia Titanium Espresso Machine
We have inherited a gaggia titanium which has done about 2500 coffees. Although the coffee runs through ok, the steam and hot water pipe does not run at all and the machine says "ventilate" regularly. I...
You might have to replace the steam valve assembly, try to get the stainless steel valve instead of the plastic one if your machine does not have it already. You can get the parts from your nearest gaggia dealer or from servicesunlimited, if yo check the importika.com web site you will find a list of all services agents and dealers.
Jul 28, 2010 | Gaggia Titanium Espresso Machine
Descaling cycle will not run
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Jun 12, 2010 | Gaggia Titanium Espresso Machine
Stuck in rinse cycle and the brew unit wont come
Allow the unit to complete the rinse cycle.
It may take several jugs of water to complete.
Feb 14, 2010 | Gaggia Titanium Espresso Machine
I have a Gaggia Titanium that is six years old. I descaled for the first time and went through the entire process.. After it rinsed I put it all back together. When I flushed the steam wand, some nasty...
HI Sorry, but you have 6 years of scale that has been broke loose and is now plugging your lines. You are going to have to take you machine apart and blow out all your lines and also the boilers with air pressure to clear the lines. Descaling is one of the most important things you can do for your machine. Your lucky that your machine went 6 years. Most don't.
Jan 25, 2010 | Gaggia Titanium Espresso Machine
Machine doesnt produce coffee
Try this, your machine has a manual/coffee grounds input, press the button for that option and see if water flows from the coffee spouts, if yes then adjust the grind on the grinder to coarser, if it gives you a ventilate error, then one of the lines to the brew unit is blocked, nd you will have to run the descale again or open machine and find blocked line and clear.
Mar 16, 2009 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
270 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
