Question about Garmin nuvi 200W GPS Receiver
Hardly used garmin cannot locate satalite - Garmin nuvi 200W GPS Receiver
  • 1,606 Answers
If it hasn'tbeen used it probably has an old set of data for the gps satellites. You may need to do a reset on it. This is in your user manual near the end for this model. I don't have that here but it will involve either pushing a reset button while turning the power on or holding down the screen and the power button or just going ino the menu and selecting reset.
Regardless of which way it does the reset this blows out the old data and then downloads the new one from the satteites. When you do this you want to have the unit charged and running on the charger. You also want to do this with a clear view of the sky to soeed it up. On the 200;s it can take as little as 5 minutes to as much as 45 depending on how many satelittles it sees and so on. Anyway you set it up , plug it in, reset it, and leave it alone utill it downloads an starts up and thats the entire process. After this is down it will now be able to synchronize the time and have a valid data map of the satelitles it should expect to see. When you use the unit more often it updates these as it boots up but if you don;t use it and this info gets outdated it won't be ale to see anything or know where it is.
Posted on Aug 23, 2010
Failure to locate satalites
This is a common problem caused by a component failure of the flip up GPS receiver assembly. More information on this topic with things to try can be found here:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Jan 24, 2011 | Garmin Nuvi 660 GPS Receiver
I swtched garmin sat nav off on the power say off by accident so now please how do i switch my sat nav on?
Simply switch it back on using the same switch. If this does not work press the reset button,see your device handbook for its location. I turn on my satnav to set the routing and after it has finished calculating the route i tend to turn it off again. When i come to unfamilliar area I turn iit back on and it picks up the satalites faster and carries on from that point. You should be able to turn on and off at will anyway.
Oct 30, 2010 | Garmin GPS
Garmin not getting satalite reception
I would try an external antenna and a firmware update. I believe there is a GPS Chipset update for that unit. Just get the free program WebUpdater from Garmins site and run it with your unit plugged into your computer. Take the unit outside and give it max 20 minutes to figure out it s location. If that does not help then it is time for a new GPS or get that one repaired.
Jul 13, 2010 | Garmin nuvi 750 GPS Receiver
I HAVE A GARMIN NUVI 255W I NEED TO UPDATE SOMEONE HELP PLEASE
You can update the software at no charge at Garmin.com but you will need a mini USB cable to connect he Nuvi to your PC.
Maps must be purchased.
Apr 01, 2010 | Garmin nuvi 250W GPS Receiver
Alternate method for installing updates to GPS units
Well maybe you could get someone else with a fast connection to Down Load and put on a memory stick?
Feb 12, 2010 | Garmin nuvi 205W GPS Receiver
296 takes forever to acquire satalites.
If you don't use it very often it can take time to find its location. Have you tried using the 'set initial location' option? Once it knows roughly where it is and what time it is it can then work out which satellites it should be looking for instead of searching for any/all of them. The manual does say that it will take time if it has no initial clue as to where on the planet it is, and if you're on the move while it's trying to work that out then it may take even longer. Obviously, if it has a poor view of the sky, or if most of the satellites are behind you and you have a tin roofed aircraft then that will probably not help either.
Sep 24, 2009 | Garmin GPSMAP 295 GPS Receiver
Tracking satalites
Update the firmware from Garmin website, and do master reset. That should fix the problem. worked on mine
May 23, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
My garmin c320 wont track any satalites
hi, my garmin c320 has a clear view of the sky but it cant track any satalites i don't know what to do. or if there is anything to do. can some please help me. thanks
Apr 29, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
Garmin nuvi 200W GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
