Question about York Exercise & Fitness
I have a T520i treadmill that keeps giving error 1 code after having followed all suggestions in manual. Do I need to have a service call or is there something else I can do?
4 Suggested Answers
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
SOURCE: my sportsart 6150 treadmill gives an error code 1
I would say that it could possibly be a speed densor fault as error one means loss of speed signal!! If the mat moves first then error one shows i would change sensor before changing anything else, if the mat does not move it could be a lower control board fault.
Posted on Feb 22, 2010
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
How do i fix my vfit treadmill error code showing on display error code 03?
If you wish to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Sep 25, 2016 | Exercise & Fitness
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Er 1 shows up when I turn the treadmill on
Error 1 can mean lots of things. The best way to figure this out is to supply the make and model when asking for help. Er 1 is used in most major manufacturers treadmills. Using your model and serial number, you may be able to find the service manual with error codes at the following link. Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Search Results
Nov 27, 2015 | Exercise & Fitness
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
What's the problem of error 1 on my york t520i treadmill that stopped working, I need your help please.
Error 1: Speed sensor error Turn the power switch off and on again to reset the treadmill. If the treadmill returns to normal operation, you may continue to use the treadmill. If treadmill does not return to normal operation, then call the dealer for advice.
ERROR 1 CODE This is a safety feature that can stop the treadmill from functioning. This error can occur because the computer is not receiving the correct information from the speed sensor located near the motor. As a precaution the computer stops the treadmill until it begins to receive the correct feedback. By performing a few simple checks, the error can be cleared quickly and easily, and the treadmill can be ready for use. The treadmill does not move and displays "ERROR 1" Switch off the treadmill at the mains, and then switch it on again. If "ERROR 1" still shows switch off and push the running mat round (1 cycle) using your feet. Then switch back on. If "ERROR 1" still shows, then UNPLUG from the mains and check all of the wire connections made during the assembly. (SEE BOLD PRINT) UNPLUG If the treadmill still does not move, then please contact the helpdesk. Doing this may reset the program error, and the treadmill will be ready to use. This should reset the sensor, and the treadmill will be ready to use. Once the cables have been checked, turn on the treadmill again. This should eradicate the problem. 1. 2. 3. When assembling, there are several cables that need to be connected. It is very common for these cables to look like they are connected when they are in fact not fully connected. Make sure that these cables are connected as tightly as possible. The connections may have come apart whilst assembling the treadmill. here is a link to your treadmill web site http://www.yorkfitness.com.au/uploaded/pdf_71T520i%20Treadmill_5562.pdf
Mar 02, 2015 | York Exercise & Fitness
Nordic Track C2200 Error Code 440-17E what might be wrong?
reset the machine, follow this step and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 21, 2013 | Exercise & Fitness
Lifespan treadmill has a dC-1 code
Reset the error follow the steps. God bless you
    • 1 Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Mar 25, 2013 | Lifespan TR800-DT Treadmill Desk
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
Mar 16, 2012 | Exercise & Fitness
Exercise & Fitness Logo
89 people viewed this question
Top York Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
ray gallant
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
