Question about Sharp AR-5316 Advanced Digital Imager Copier
What does error code H2 mean? - Sharp AR-5316 Advanced Digital Imager Copier
  • 61 Answers
Fuser trouble, thermistor open. Check for proper fuser intallation.
Try P * C * sim 14 and try and clear the code
Posted on Aug 23, 2010
Bosch tankless water heater error h2
H2 wasnt an error code on those machines... could you check the display and ask again?
Feb 11, 2014 | Bosch & Tankless LP Hot Water Heater
Code error H2
h2 means the open the termistor.
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 03, 2012 | Sharp SF-2025/2030 Copier Toner Black...
How to initialize SHARP 5127 after Code error H2-00 appers
Hi Ambroise,
The error H2-00 means there's a problem with your thermostarts/fusing unit.You need to check them for they may be blown.Replace the fuser if damaged.To reset the code,push P*C* then 14 and then press on the start button[the one you use for copies making].The code is reset.If not,then you need to replace the fuser.
Hope this helps.Thanks!
Please rate this answer.
Nov 17, 2011 | Office Equipment & Supplies
Code error h2
Hi
Error code H2 means fusing unit temperature error. This error occurs due to a bad fuser temperature thermistor or due to fusing lamp. To resolve this error try and reset the unit by entering the service mode--
press # - INTERRUPT - C - INTERRUPT
then
14
start
If this resolves your issue then try restarting the printer and try the reset again. However, if reset is not helping you then you
Oct 09, 2010 | Sharp AR-5316 Advanced Digital Imager...
E 91 01 THE FLASH DOESNT WORK AND IT GIVES THIS ERROR CODE
Just go in "menu", "set up 1", "initialize", and select "ok". With that you will reestart your camera. I already did it twice in my DSC-H2 and the flash came back to work. Goo Luck!!
Jan 31, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
What does it mean when h is flashing
There is a problem with the fuser unit , H2 means thermistor open or not connected, H4 means low temperature or fuser lamp not working. Reset with by pressing ; # , Interrupt , C , Interrupt. Display will go off then enter 14 and press Print key.
Jul 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
H2 00 problem
Try to reset the error code by pressing these buttons :
[#] [interupt] [c] [interupt] [1] [4] [start/copy]
If the error code still exist check the thermistor and it's connection and reset again.
May 21, 2009 | Sharp AR-275 Copier
Hummer H2 SUT DTC Code C0563
C0563 - Calibration ROM Checksum Error
Not sure what it means but thats what I found when I looked it up
Oct 27, 2008 | 2005 Hummer H2
H code
not familiar with the model number but H codes usually refer to paper tray lift failure - H2 tray 2 etc.H1 tray 1- are all your trays working ?
Dec 23, 2007 | Office Equipment & Supplies
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
95 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
