Question about DKNY Watches
After purchase. i noticed the battery was weak. I have not been able to open the back cover.
    President:
  • 2,501 Answers
If you have a problem with a new watch, return it to the seller. If you attempt any self repairs, you will invalidate the warranty.
Posted on Aug 23, 2010
Is there a watch battery replacement for aFossil Architects 371 battery
There are plenty of charts for battery equivalent on the Internet.
so open and remove battery then identify or bring to battery store to purchase new one.
opening the back you may need spanner type tool.
it may be easier to just bring to battery store for replacement.
i purchased tools and batteries from Amazon for doing watches in family. Figured saves about $80.00.
proper tools will help don't forget a closing clamp for snap close styles.
Oct 01, 2016 | Watches
Tip
I too started unscrewing the back but decided it wasn't going to well! Your...
When you need frequent re.Syncronizing of your Touch or after 2-3 year
maybe you need to replace the battery.
you need:
a CR1632 3V Battery (about 2€)
a very tiny screw driver
a very sharp knife
With the knife remove the bottom of yout Tissot, (you do not need to unscrew) it's just a cover to pull up like in this imagedcef0c0d.jpg
Now you can clean with a soft brush & remove the dust.
Use the screw drive to replace the battery,
put back the cover & enjoy
on Jul 06, 2009 | Tissot T-Touch T33759851
I recently purchased a GWR Pocket Watch from York Railway Museum. I can open the watch to see the time, but cannot see how to open the back to adjust it (it is currently on BST) or to change the batt
All watches open from the back. Closely inspect the back cover and find the depression in the edge that a thin knife edge can pry open the cover. Search carefully and pry open but do not force. Most watches are very tightly sealed to prevent moisture from entering, however, if you can pry open at some point along the back cap, look for a thin rubber gasket. If there is not a gasket no worries. Use a C-clamp or hand-vise to clamp the back cover tightly. Be sure to allow the stem slot, adequate clearance so you don't damage it. Look for a "dip" in the case back and locate stem. Hold in place with tape while you squeeze the back into place using the c clamp or vise slowly.
Jan 07, 2015 | Watches
Just change the battery on my Nike Anvil WC0020 watch and the alarm won't sound for the timer as well as the two alarm settings.
If you changed battery yourself, you've lost the tiny spring without noticing it. Carefully check around the place where you changed the battery. The spring itself is very, very tiny, so, be as concentrated as much as you can. That spring (coilspring named by watchmakers) transmits the signal from watch movement to the watch back cover where the sound membrane is located. In case if you find it, open the watch and insert that spring with the bent out end first in to the desired hole in watch movement (should be named COIL SPRING). After that re-assemble watch and the sound should work.
Jun 02, 2011 | Nike Mettle Anvil Super Watch Obsidian...
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    I have a Majestron quartz pocket watch. How do I replace the battery?
  • Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
  • Remove the circular watch battery out of the back of the watch.
  • Take the battery to any department store or watch store and purchase a new replacement battery.
  • Insert the new battery into the back of the watch.
  • Screw on or push on the back of the watch. Set the watch to the correct time.
  • Aug 23, 2010 | Watches
    I want to change out batteries
    1. Lay the watch upside down on top of a towel or cloth on a flat workspace. Use a small flat head screwdriver or blade to pry under the watch backing, then lift the backing from the watch. Slide the battery cover to the side to access and remove the battery.
    2.Take the battery to any electronics store to purchase a replacement. Bringing the old battery will ensure you install the correct type of battery in your Fossil watch.
    3. Replace the battery and the battery cover. Apply pressure to the backing until it "pops" back into the watch.
    THANK YOU FOR VISITING FIXYA
    Aug 05, 2010 | Fossil Dress - Analog Glitz Red Dial Watch
    How can get sound on my iroman 8 lap watch after changing battery. I wander if there should be a tape in the back cover and if yes to what extent it should cover. when I set my alam I see the fainting of...
    mcdevito75 here, It"s possible the NEW battery in your watch is weak from an extended shelf life, I'd return to the place the battery was installed and ask. Also you can go over your watches functions again as the watch has to be re-set once the battery is changed.
    Jul 15, 2010 | Timex Watches
    Battery replacement
    do you mean you want to replace the battery for your watch?
    This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
    Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
    Good luck.
    May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
    I have changed the battery in my Casio 1604 a200 watch but now the screen isn't displaying correctly. Is there anyway of resetting the watch?
    I realise this post is 4 years old now but what the hell! If you open the back of the watch you will notice in the top left corner a small hole with the letters AC above it. Push something metallic into the hole to make contact with the metal backing. This will reset the watch and the display should then be fine.
    Shane.
    Apr 15, 2008 | Casio Watches
    Watches Logo
    249 people viewed this question
    Top DKNY Watches Experts
    Ansel Alberto
    Ansel Alberto
    richie46
    Are you a DKNY Watch Expert? Answer questions, earn points and help others
