Question about Samsung AS18A6RB Air Conditioner
Hi, I have Samsung AQ18U Air conditioner split unit, i have it installed only 10 days ago, and the warranty as bad as possible, the problem description as follows: 1- i turn it on it works for approxmitly 30 to 40 minutes 2- then suddenly it closes the fan exit and a green light flashes from the smart saver indicator. 3- i turn it off , then turn it on and the cycle repeats again. Please any one help me
  • 38 Answers
Change the thermister
Posted on Sep 02, 2010
  • eng_moham635 Sep 02, 2010
    Hi technic_7117,
    Thanx i just replaced it 2 days ago but no luck , a new thing happened now it wont restart again after i turn it off and then turn it on instantly it gives me the green light flashes, if i leave it off for hour or two it starts again work for 30 minutes and then closes again and the cycle repeats.
  • eng_moham635 Sep 13, 2010
    All , i hope someone will make use of this info, after a long try and error approach i replaced the following , both thermistors in the AC, changed the main board , and finally the problem was in the FAN!!!!!! so i replaced and everything went ok, although i dont know whats the relation between smartsaver indicator and fan fault but never the less i got it working , thanks for every one.
I have a split unit that was installed about 8 months ago. It worked fien until the hot summer came. Suddenly it began to drip on the wooden floor beneath it. I checked the drain outside and it seemed to...
If your unit is only 8 months old, then it should still be under warranty! Suggest you check the drain line to make sure that nothing has decided to make it home.
I would check the level of your unit to make sure that there is a slight grade to the rear of the unit, but I hesitate to tell you to shim it.
Jul 26, 2011 | Mitsubishi MS-A09WA Split System Air...
4 months ago purchased as183 uganstl 1.5 tonne split ac samsung is not cooling. no presence of gas (gas leaked) service person could not find where the exact problem is . how to solve?
If the gas has leaked, try recharging after checking all the joining flanges are fully tightened.
I hope this unit should be under guarantee and avail warranty repairs.
Sep 23, 2010 | Samsung Heating & Cooling
I have no cold air coming from vents but cold air coming from where the filter is in my hallway celing. The unit was installed brand new a few years ago
The indoor blower motor has probably gone bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 06, 2010 | Heating & Cooling
I have a Carrier AC unit with a heat pump. I noticed that it wasn't cooling and the circuit breaker had tripped. When I reset the breaker and try to start it again, it trips againafter 10 seconds. The...
Check with your contractor to see if their repair is warrantied. If it is not call someone who carries a warranty and satisfaction guarantee on repairs. It is likely that you got a bad capacitor, however, this typically will not trip a breaker. It's possible that other issue(s) caused the capacitor failure.
How old is this unit?
Aug 26, 2010 | Carrier 38CKC060 Air Conditioner
Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
May 08, 2010 | Samsung AS18A6RB Air Conditioner
Remove and relocate split air conditioner
The simplest way of explaining this is as per the following. On your outdoor compressor unit there should be two pipes, one smaller diameter [high pressure] and a larger diameter pipe [low pressure]. Turn your A/C on inside the house and then shut off the smaller diameter pipe. Run the unit for a around 3 to 4 minutes and then check if the cooling is reducing from the unit inside the house. When you feel room temperature air [not cool] being emitted from the indoor unit shut off the larger diameter pipe and turn off unit. Isolate electrics, disconnect A/C piping and immediately seal the piping with good quality tape to prevent egress of dirt. When re-installing a quick purge of gas is usually only required to clear the lines if they were sealed properly and kept clean. Ideally running a vacuum pump is recommended but if care was taken then it may not be needed, as in many of my installations.
Jan 09, 2009 | Heating & Cooling
Split unit a/c - works but no cool air only air. I was told the compressor broke and would need to be replaced at a huge cost.
The warranty usually reflects the worst case life expectancy. In other words if your warranty is for 5 years then they expect that if the unit was to be run consistently with regular to no maintenance It will only last 5 years.
These systems are very expensive. But that is not because of there longevity but for their unique applications. Manufacturers are not selling nearly as many Mini splits as they do regular split systems. So it is really just a supply and demand situation.
Jul 02, 2008 | Samsung AS18A6RB Air Conditioner
Samsung AS18A6RB Air Conditioner Logo
864 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
